I am looking at building my 4th router. This one will be a 4' x 8' machine and it's primary use will be cutting cabinet parts out of MDF, Melamine, Plywood, etc as well as doing a bit of Solid Surface Material and Solid wood. Sheet Goods Primarily. Will be cutting for myself as well as others, so I condiser this a serious hobby machine. My goal is to route sheets in a single pass at good speeds - perhaps comparable to a Shop Bot.
I have drawn a machine up in CAD made with 8020 extusions. The X and Y axis to be supported by 3060 extrusion, the legs out of 3030, and the rest out of 1530 and solid aluminum. Drives will be Rack and Pinion.
My questions is, how solid is this design and could someone critique it? In the back of my mind I am thinking I may want to go with steel instead of extrusion for the vibration dampening ability and sheer mass.
My problem with this is I cannot weld, do not have the tooling to cut it, and would have to farm this out at additional cost.
With the cost of extrusion being so high, I was considering steel, but with the soutsourcing needed to cut weld, paint, etc the cost is closer to what the extrusion would be.
So I come back to design. Is ther a big benefit either way?
Dan
