586,983 active members*
3,623 visitors online*
Results 1 to 7 of 7
    Dec 2005
    68
    FANUC 21 TB RS232 PROBLEMS
    I have a daewoo linx 200 and there is not sending data , i use an Rs232 tester and looks like the ic (chip) for output is not working .
    Does any one know the IC number ?
    Jan 2006
    121
    Just want to clarify. Does the communication works one way but not the other? i.e. will read but not punch? How recently was this functioning? FYI. You will not be able to replace the RS232 related components on 21TB easily. They are surface mount type components. Please also post main CPU board number.
    Dec 2005
    68
    Quote Originally Posted by fanuservicetech View Post
    YES the machine READ but not PUNCH , it was working monday
    the machine is working at this time so i can't get the cpu board # , but i know that the connector on the board side is XJD5A and the terminal to follow is "11" , i have to take the board and follow the circuit from there.
    2932
    You say the machine will punch but not read. What happens when you try to read? Do you get an alarm?
    Dec 2005
    68
    Quote Originally Posted by dcoupar View Post
    sorry i correct my self
    No the machine read (receive ) programs but do not send so y can't get out the programs from the machine .
    2932
    What happens when you try to PUNCH? Does OUT blink on the CRT? Any alarms?
    Dec 2005
    68
    YES OUT IS BLINKING BUT NO ALARMS
  1. Boss nine rs232 problems
    By Plateroom in forum Bridgeport / Hardinge Mills
    Last Post: 09-20-2008, 11:29 AM
  2. Fanuc OM-D Rs232 problems
    By SpringKing in forum Fanuc
    Last Post: 09-13-2007, 10:18 PM
  3. Rs232 Problems
    By j-radkemachine in forum Haas Mills
    Last Post: 05-09-2007, 09:21 PM
  4. Fanuc RS232 problems
    By wsuwrhr in forum DNC Problems and Solutions
    Last Post: 09-04-2006, 07:25 PM
  5. Problems you have or had with RS232?
    By gar in forum Polls
    Last Post: 12-22-2005, 05:21 PM
