586,516 active members*
3,799 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > HELP WITH VERTICAL CENTER BRIDGEPORT BPC-250V, FANUC 11M, 1986 MACHINNE
    Aug 2008
    Exclamation HELP WITH VERTICAL CENTER BRIDGEPORT BPC-250V, FANUC 11M, 1986 MACHINNE
    Hello, as are all?
    I have a vertical center Bridgeport PCB-250V with Fanuc control 11M. dated 1986
    I introduced the following judgement.
    When running a program from the peripheral (lapte op) all axes are moved according to the lines read, gives me a work stoppage when the runs the G43 line of code, stopping the team without being able to resume reset, it can only continue to operate when the machine shut down completely. The display does not present any parameters of error.
    The electrical connection is through a phase converter Des co-new 20 hp.
    Previously implemented programmes successfully.
    Jun 2008
    1511
    Can you post the code that it is stopping at so we can take a look at it? There is nothing different about the G43 line in the previous programs you say work?
    Stevo
    Aug 2008
    thanks for your advice, I make some testing jogging axes manually and the result is not problem moving X and Y axes, but when I tried to move manualy the Z axes it moves upright ut the Y always but dowm Z minus it doesnt move, Now when I use the MPG I can move the Z axes on both direction + and - any time, but when go back to auto or jogging mode the z axes only moves downright. Other test it do was use the alarm and self diagnostic software that the fanuc control have and on the display position deviation amount appear 3000 number that stay steady but the Y and Z axes blinking, changing 0 and 1 intermitentenly. What do you think it is?
    Aug 2008
    previosly I post about four drilling programs using g43 and it works OK!
    Jul 2004
    9
    Try mantenance
    Hi. probably you must check the electrical contac on front control panel, and clean those push buttons and also check the motors carbons.
    good Luck!
  1. Fanuc 11-T CNC lathe center programcode
    By manoharan in forum MetalWork Discussion
    Last Post: 08-24-2008, 06:33 PM
  2. DMG Deckel Maho Vertical Center DMC 1035V
    By CNCCS in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-12-2008, 05:58 AM
  3. CNC Vertical machining center
    By soumen in forum Mori Seiki lathes
    Last Post: 03-11-2008, 03:06 PM
  4. ACROLOC series 10 Vertical Milling Center CNC
    By DieGuy in forum Uncategorised MetalWorking Machines
    Last Post: 07-20-2005, 11:12 PM
  5. anyone knows about Mazak Vertical Center?
    By kamran67 in forum Uncategorised MetalWorking Machines
    Last Post: 07-04-2005, 05:55 PM
