586,414 active members*
3,192 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How to cut jobs longer than the table using a gerber saber w/artpath
    Aug 2008
    i operate a gerber 408 saber and im trying to cut a 115" job on my 101" table. Will someone give me a pointer on how to handle this?
    -Felix
    Mar 2008
    683
    Indexing holes
    This is an easy one.
    Drill some index holes in your spoilboard and drill matching index holes in your part in some waste area. Then offset a new set of indexing holes in the waste area. Set some dowel pins or rod (I use 1/2 wood dowels) cut the first part of your toolpath up to the area of your table, or index offset, shuffle the project down to the spoil board index holes, align the offset project holes, reinsert your dowels, and now you can run the rest of your toolpath.
    Aug 2008
    thats crafty
    I'll have to try that one out next time. I ended up centering the job on the material, inverting the job diagram and and flipping the entire piece on the table. The only problem is i had no solid waypoints so accuracy was lacking
  1. gerber saber 408
    By schantal in forum Gerber
    Last Post: 09-25-2018, 09:29 PM
  2. Jobs!! Jobs!! Springville NY Jobs!! Jobs!! Jobs!! Jobs!!
    By HBP in forum Employment Opportunity
    Last Post: 11-15-2007, 04:41 PM
  3. Replies: 1
    Last Post: 06-07-2007, 07:35 PM
  4. light saber
    By go-off-road in forum Mini Lathe
    Last Post: 09-08-2006, 05:43 PM
  5. 4th axis add on to a shop saber
    By dac in forum DIY CNC Router Table Machines
    Last Post: 08-23-2004, 03:58 AM
