587,418 active members*
3,752 visitors online*
    Apr 2006
    125
    Run time estimation
    Hi Scott,
    Just installed the latest version.
    On machine configuration (Lathe), I just noticed there's no Run time estimating dialogue box to configure the rapids + t/c time (as there is in the mill)?
    Cheers,
    Terry
    765
    Terry,
    You don't get the dialog box at all? What happens when you click the menu for run time estimating?
    Scott
    Apr 2006
    125
    Hi Scott,
    If I generate a report, it gives a rapid rate of 100, with a tool change time of 5 s (defaults?).
    Cheers,
    Terry
    765
    Terry,
    There are settings in the Machine Configuration now for the rapid rate and tool change time. These are probably what you are seeing.
    Scott
  1. First time with CNC
    By witisi in forum Community Club House
    Last Post: 05-04-2008, 11:28 PM
  2. Run Time
    By Tazzer in forum Haas Mills
    Last Post: 03-29-2008, 02:46 AM
  3. milling time (not to be confused with hammer time)
    By barefoot0 in forum G-Code Programing
    Last Post: 05-03-2007, 12:18 AM
  4. X2 Conversion Time (shopping time)
    By Micro Rotors in forum Benchtop Machines
    Last Post: 03-04-2007, 06:11 PM
