586,471 active members*
4,128 visitors online*
    Jan 2007
    172
    "wrong program data" when file transfer????
    BP II interact 4, TNC 150
    My old desktop died this morning, had all my transfer software on it. I set up my laptop and I already had a usb/serial connector on standby. Installed fine, I am uploading to the 150, but when it finishes uploading I get the "wrong program data" alarm. I can hit "exit" then "no enter" and when I look at the program that I just transferred, it is all there, every single character.
    I could just keep doing that, but I would rather do it right, like I used to. I am using a new software, "predator dnc". I used to have to put a "13" at program head, and a "13" at the end of the last line. I have tried that and tried switching the last "13" for a "3" on the last line by itself. Still same alarm, still get all my program. Any help is appreciated.
    1121
    re
    Not uncommon. The program is probably putting a spurious character at the end of the program. Should be a setting for it. Unfortunately I don't know what the right thing is.....
    4826
    How does your new software send control characters to the machine? The numbers would most likely be associated with ASCII values and there are only probably a half dozen that get any usage. Check here: http://www.asciitable.com/
    Perhaps try a simple program download to your PC and see if you can catch the correct characters that way. I suspect it is looking for a particular termination character, but the way that this is encoded into the DNC software could vary from program to program. For example, some programs use @003, others use ~003 to represent ASCII 003.
  1. Save file with ".cdl" extension
    By PinMan in forum BobCad-Cam
    Last Post: 04-02-2008, 10:34 PM
  2. "INPUT BUTTON NOT FUNCTIONAL IN PROGRAM MODE"
    By offroadxx in forum Fanuc
    Last Post: 03-26-2008, 12:56 PM
  3. vickers 2100 - Tree J250 - program "rewind"
    By mblazenby in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-11-2008, 04:39 PM
  4. Fanuc O-MC Alarm 405 "Z axis wrong (ZRN)"
    By JSaindon in forum Fanuc
    Last Post: 09-19-2007, 04:22 PM
  5. Data-cut plans "opinions wanted"
    By GreentreeCNC in forum DIY CNC Router Table Machines
    Last Post: 12-15-2004, 11:11 PM
