Is anyone using this router?
http://www.kelinginc.net/CNCmachines6090.html
I am wondering if there is a shop here in Central AZ that I can contact and see how good this machine is?
Would also like to hear form the company that sells it.
I've email them already but though I place the question here as well.
Is the machine made in China? or Here in the USA?
Ball Screws or ACME and BSA nuts? Rails? Round Square?
From the spec on the site seems that a retrofit is done in house to these machines to make them work with Mach 3.
I am asking all these questions because I cannot afford to experiement with products. I need to get my shop back in motion and need a good small CNC router or a quick retrofit to my existing router as my other posts indicate.
What type of controller comes with it?
What are people using it for?
I like the size and the spindle looks interesting , water cooled? air driven perhaps? and it could be a nice upgrade to my existing MAXPATH42 that I've been having issues with lately.
TIA
Brand New CNC Router Engraving Machine with Mach3 Controller,
1.5KW Spindle + 1.5 KW Variable Frequency Drive
We changed this machine to Mach3 controlled Syetem.
Machine Size: 960 x1320 x1200 mm
Working size X,Y,Z : 600 x 900 x 100mm ( about 23.6" x 35.4" x
3.9")
Working speed : 3m-8m/min
Resolution: 0.05mm
Mach3 Controller, with Mach3 License software
Spindle Power Motor: 1.5KW, Water-Cooled
Water Pump with Tank
Spindle Speed: 0-24000rpm w/VFD, AC220V/50Hz
X, Y, Z axis driver: Stepper Motor Driver
X, Y Z Limit Switch
6 Axis Breakout Board Optical Isolated
E- Stop
Wood Packing Size: 1380 x 1090 x 1400 mm
