586,608 active members*
3,398 visitors online*
Thread: X4+ 4axis
    Sep 2006
    102
    X4+ 4axis
    How does one set up the 4th axis on a X4+?
    All I can make it do is run around in circles.
    Can some one assist?
    Martin
    Jun 2007
    3757
    Talking Stop it running.
    It is probably running continuously because the limit switch is enabled for the A axis. When you REF the machine the axis starts rotating. You really don't need a limit switch, so disable in the config (pins etc..)
    Now just JOG it around to zero using page-up/down and zero the DRO.
    A45 now moves to 45 degrees. Depending on the config page settings A-5 or A355 may go the long way from here, or the short way. I like the short way.
    I prefer to fit a 6 pin plug (with at least 5 amp contacts) on the 4th axis.
    6 Pole JAYCAR IP67 multipole connector and socket is perfect. There is also a screw cap cover available.
    It is VERY IMPORTANT that the power is off when plugging or unplugging 4th axis. A voltage spike can damage the driver and void your warranty.
    Sep 2006
    102
    4 axis plug
    DSCN1407.pdf
    Just a little reminder to switch off the power prior to conecting/dis-connecting the 4 Axis.
    Martin
    Martin
    Oct 2007
    166
    Hehe nice touch with the sign.
    Thankfully I distrust machinery to the extent where I always switch it off before doing anything such as setting up the 4th axis. Even the spindle lock mechanism I did kicks in the emergency reset whilst it is engaged during a tool change. Hopefully a power draw bar will make that a thing of the past.
  1. HELP! Need datasheet for aliencnc 4axis stepperboard
    By glenngb in forum Linear and Rotary Motion
    Last Post: 06-17-2008, 05:38 PM
  2. Need some help please, datasheet Aliencnc 4axis board
    By glenngb in forum Controller Cards
    Last Post: 03-25-2008, 08:23 PM
  3. 4Axis Format G-code Example
    By louis14 in forum G-Code Programing
    Last Post: 07-27-2006, 05:15 AM
  4. L297-8 and 4axis BOB
    By aem_argentina in forum Open Source Controller Boards
    Last Post: 02-20-2006, 04:55 PM
  5. Cool picture of our 4axis
    By Gujustud in forum Community Club House
    Last Post: 01-24-2005, 11:22 AM
