586,973 active members*
3,307 visitors online*
IndustryArena Forum > Community Club House > interest in SD to CNC g-code product?
Hybrid View
    Jun 2008
    52
    I'm in the middle of a small microcontroller device that allows one to bypass the need for a computer to run a CNC.
    Features
    -SD card reader
    -RS232 port
    -LCD display
    Operation:
    -You put the CNC in DNC mode
    -You select the file off the SD card and it drip feeds the program over RS-232
    Benefits:
    -any size program, not limited by CNC memory
    -no external computer required
    -easy transfer of gcode from one computer to CNC
    -possibility to be integrated with the auto tool zeroing board I made (select what tools you want to zero and the board does it automatically)
    Cost is to be determined but I'm thinking it'll be in the $250 range depending how much demand there is for it. The more demand the cheaper the boards are so if you have an interest in this device, send me a PM.
    It's a lot cheaper than an upgrade to the USB drive, floppy drive or harddrive from the manufacturer. Sure you could do the same with a cheap laptop with a SD reader running a DNC drip feed program but it'll still probably cost more than $250.
    Sep 2006
    607
    What features will it have? How many I/O lines? Can you edit the G-code on it?
  1. What Is your interest in CNC?
    By widgitmaster in forum Polls
    Last Post: 09-26-2017, 09:37 PM
  2. ANy interest in a tutorial?
    By CyborgCNC in forum Musical Instrument Design and Construction
    Last Post: 07-12-2014, 05:14 PM
  3. my site may interest you
    By vacpress in forum Community Club House
    Last Post: 05-31-2006, 07:51 PM
  4. What are your other interest?
    By cncadmin in forum Community Club House
    Last Post: 05-23-2005, 11:11 PM
  5. Would this interest anyone?
    By DAB_Design in forum Employment Opportunity
    Last Post: 06-22-2004, 02:21 PM
