586,389 active members*
3,087 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > okuma tool registry bug
Results 1 to 20 of 21
    Jul 2008
    139
    okuma control doesn't know what tool is in spindle - if tool 1 is in spindle and "T1M6" is called machine alarms -- macro is needed to check tool registry for tool in spindle before tool change then jump past tool change line if sp T# equalls called T# WHY CAN'T OKUMA AVOID THIS BY HARDCODING THIS FUNCTOIN INTO THE MACHINE'S FIRMWARE ? If anyone has a beeter alernative to coding macro before each toolchange PLEASE LET ME KNOW!
    THANX [email protected]
    Jul 2008
    41
    A macro is the best way to do this really, and you can use the same unmodified macro for all your programs regardless of your starting tool. In your macro, use T=VC** (Use any common variable you'd like to dedicate to this), then before the macro call in your program, set that variable to the first tool (VC**=1). That's the most simple way to explain it. Unfortunately, I think it's gone so long without being fixed is there is a well-known, easy workaround for it. The good news is their lathe programmers have always had the code right, and it has made it's way into the Macturn/Multus platforms, so perhaps it will migrate into the mills soon too
    Jun 2003
    513
    Put this at each tool change. You'll need to number your sequences accordingly.
    IF[VATOL EQ 2]N2
    T2
    M6
    N2
    M1
    T3
    (TOOL 2)
    (.97" CARBIDE ENDMILL)
    (OPERATION 3)
    G0 G90 G15 H1 Xx.xxxx Yx.xxxx Sxxx M3
    Jul 2008
    41
    Program branching is only allowed in A method. If you are in B method (large volume method), DNC-B (RS232 trickle feed), or DNC-DT (trickle feed from a hard drive in the machine) you have to use the macro method.
    Jun 2003
    513
    The IF statement above works in both A & B methods and does not violate any of the restrictions for either method. I use this in all of my Okuma posts on every tool change sequence.
    Jan 2008
    575
    I agree with the mastercam guy, I have the utmost respect for okuma, I have run them all, Mori, Daewoo, Haas, Mazak, I am not bias to a mill or a lathe, and I think Okuma builds the best machines out there, that being said I think that the whole tool change situation on that mill is a little frustrating, too many steps to accomplish a simple task. just my opinion.
    Apr 2006
    822
    Seems to me that this is user problem, NOT an Okuma "bug".
    The mills do know what tool is in the spindle, otherwise why the alarm?
    If YOU the programmer selects the incorrect tool then YOU are the one at fault, not the machine, or the software.
    On the other hand, if the operator selects the wrong tool without knowing what it is that they are doing, then the machine is really only guilty of protecting itself.
    If you are getting tool selection alarms during a program run I would be more concerned, but I really fail to see what your problem is. Maybe I have got the wrong end of the stick, but mayb not also.
    Anyway, just my 2c worth.
    Brian.
    Feb 2007
    592
    Arrow Tool Change alarm.
    Quote Originally Posted by mastercamguru View Post
    The alarm is perfectly valid. The Okuma KNOWS exactly which tool is in the spindle, you didn't ask that.
    You have told the machine "T1 M6" and the machine checked the tool magazine and there is no T1 in the magazine. You gave it a tool CHANGE command.
    I use a macro check like above but a bit more detailed.
    DIREC V
    ORIGIN Hxx
    CYLNDR 2P,[0,0],[100,100],0,10
    END
    DRAW
    N04 IF [ VATOL EQ 1 ] N10 (TESTS ACTIVE TOOL)
    N05 IF [ VNTOL EQ 1 ] N09 (TESTS TOOL IN READY POT)
    N06 IF [ VNTOL EQ 0 ] N08 (TEST FOR NO READY TOOL)
    N07 M65 (RESET READY TOOL)
    N08 T1
    N09 M6
    N10 G00 G15 Hxx M8
    The macro does the job and acts as a safety net if the operator hits reset (such as a machine going into power save during lunch.) It makes sure the machine has the right tool at the program start.
    ( Oops, I didn't need to include the graphics plot header...)
    (As M$ might say, "Its not a bug, It's a Feature.")
    Now on the other hand, the Mazak lathes I use will do almost anything you tell them, like index the turret while in a bore if the programmer isn't smart enough to put the Txxxx in a safe location.
    Jan 2008
    575
    Question
    Broby and Skullworks, you really dont think that this is maybe a little more complicated a tool change (mechanically and code wise) than it needs to be? I have had Hartwig tell me that nobody really complains about the tool change, but to me it seems over complicated, but I do alot of hand editing. Just wanted your opinions.
    Feb 2007
    592
    Cool Tool change compromises
    Every Machine builder has choices to make on how they choose to implement a tool change cycle.
    On the Okuma an M6 takes the spindle home to the tool change position (Vertical Mill). Same for Haas. Try that on many FANUC's without doing a G28 G91 Z0 first and you will get an alarm... Some might say THAT behavour is a bug/error. Its not - its just the way the tool builder chose to do it.
    Jan 2008
    575
    I agree with that, but "tool change cycle" getting back to my first point why does it have to be a cycle? (yes I understand that all things need to accomplish specific steps before the goal is achieved) The Haas does not use a "cycle", it is just a tool change, let me say again I am less unimpressed by any machine tool manufacturer than Okuma but I think that tool changer sucks. I work with a lot of operators that make it more diffficult than it has to be (surprised?) but on a Haas when something goes wrong with the tool change, you push the button that says toolchange restore and it walks you through it, easy? Not so much with the toolchanger on those mills. I think. Every manufacturer does have decisions to make, and most of the reason i have stuck with Okuma is that they are so freindly, just this one gripe from me.
    Apr 2006
    822
    If the machine has stopped mid tool change, use the ATC manual Advance/Reverse buttons on the operator panel to recover. Either that or use the ATC "Return to Cycle start" button. Works wonders here when things go potty.
    Why, as a programmer, do you feel the need to check what tool is in the spindle?
    YOU should already know what tool is there. You programmed it didn't you?
    Surely you start off with no tool in the spindle, call up the first tool, Tool change, call up the second tool, and start machining. i.e.
    T1
    M6
    T2
    M3 S...
    M8
    G0 x.. y.. z..
    etc...
    Machine somthing... with Tool 1
    M9
    M5
    G0 Z800
    M6 (Get tool 2 into the spindle)
    T3 (Pre-stage TOOL 3)
    M3 S...
    M8
    G0 x.. y.. z..
    etc...
    Machine somthing... with tool 2
    M9
    M5
    G0 Z800
    M6 (Get tool 3 into the spindle)
    M63 (tell the machine that there is no next tool)
    M3 S...
    M8
    G0 x.. y.. z..
    etc...
    Machine somthing... with tool 3
    M9
    M5
    G0 Z800
    M6 (Return tool 3 to the magazine)
    M2 (end of program)
    See, no need to check what tool is in the spindle, you know what is there!
    My programming method and 2 cents worth.
    Cheers
    Brian.
    Jan 2008
    575
    Brian, I think you know alot more about this than me, and if it is really that simple I am going to kick myself in the... well you know. But on my machine I get a frozen machine (no alarm, just wont move) if I try to call up the tool which is in the in the spindle, depending on the sequence. But the way you just wrote it out, I can stage a tool without fat fingering? IF(vatol eq #)goto N# is that correct? If so I have been wasting a huge! amount of time. Please tell Im an idiot because in the future it would save me alot of time. By the way control is e-100.
    Feb 2007
    592
    Arrow RTFM
    Check your manual for a M63, M64, M65
    Its been awhile but if I remember correctly the M65 resets the assigned ready tool and M63 or M64 returns the tool in the spindle to an empty pot ( no next tool ).
    So (RESET), (MDI), "M64" (WRITE), (START) = should remove the tool in the spindle. Then if the program calls a tool change you could just go to (AUTO)(START).
    Hope that helps.
    Jan 2008
    575
    I am going to try it tomorrow. Seriously, though I am going to be pissed if its that easy.
    Apr 2006
    822
    M6 = tool change, i.e. tool is moved between Spindle and Sub pot and then returned to magazine. Machine will only complete this successfully if there is a next tool to come into the machine or if a M63 is used first.
    M63 will tell the machine that there is not going to be another tool put into the spindle when the next M6 command is used. i.e M63 and then M6 will return the tool to the magazine.
    However... (don't you love the way there is always a however...?)
    if you have already got a tool waiting to come into the machine (pre-staged) you need to use M64 to return the pre-staged tool to the magazine and then use M63 then M6.
    M64 used to return pre-staged tools
    M63 No next tool
    M6 tool change.
    Never used the M65 command so can not comment on that code.
    Regards
    Brian.
    Oct 2014
    Re: okuma tool registry bug
    SECOND THAT! tired of calling a different tool all the time
    Apr 2009
    1262
    Their software is not a bug it's just the way it's designed to work. I agree that it could make it more user-friendly. I use this tool change macro in order to make your tool change woes go away.
    Enter this as a library program so that it is always available to all your programs.
    OTCHK
    ( SET GCODE PARAM. G111 TO OTCHK )
    ( AT TOOL CHANGE KEY IN G111 T= TOOL NO. Q = NEXT TOOL EX: G111 T1 Q2)
    IF [ VTLCN EQ PT ]NST1 (ACTIVE TOOL)
    IF [ VTLNN EQ PT ]NRT1 (NEXT TOOL)
    IF [ VTLNN EQ 0 ]NOT1 (NEXT TOOL)
    M64
    NOT1 T=PT
    NRT1 M06
    NST1
    IF [ PQ EQ EMPTY ]NEND (IF READY TOOL EMPTY/JUMP )
    IF [ VTLNN EQ PQ ]NEND (IF PREP TOOL IS AT NEXT TOOL POS./JUMP)
    IF [ VTLNN EQ 0 ]NTT1 (IF NEXT TOOL HAS NO VALUE)
    M64 (NEXT TOOL POT RETURN)
    NTT1
    T=PQ
    M356 (NEXT POT ADVANCE)
    NEND G56 H=VTLCN
    D=VTLCN
    RTS
    PQ DEF: WHEN P IS ATTACHED TO A LETTER IT BECOMES READABLE
    Makes tool change frustrations a thing of the past.
    Best regards,
    Ps: if we can do it why can't Okuma? ;-)
    May 2011
    27
    Put me in the camp that thinks Okuma's tool change command should be more intelligent. The ATC errors are a hassle to me when
    I change my mind on what tool I want, re-work or etc.,etc.(on an OKUMA 4020 VMC) I decided to solve the problem and add a lot
    of new features to my tool change command.
    My ATC command works in a program or by MDI and doesn't care what tool is preselected or in the spindle or not. It will work
    every time. The OM6 program below is one of many programs I put in a 'folder' named: OKUMA.LIB which loads into RAM when you
    turn on the machine in the morning.
    On your G/M screen set G116 = OM6. In MDI for example use G116T5 instead of T5M6. If T5 is already in the spindle it will not
    error out. If T1 was preselected and T2 was in the spindle my pgm will put T1 back in the tool drum, preselect T5 and then
    put T5 in the spindle (returning T2 to the drum also).
    The full set of my G116 tool change commands are as follows:
    T = Tool number (T is required the rest are optional)
    P = Preselect next tool number
    A = Drill point angle (Calculates drill point length and puts the value in VC8)
    C1= safe tool change position #1
    C2= Safe tool change position #2
    L = Min tool length requirement (Used with a positive number)
    L = Max tool length requirement (used with a negative number)
    Now for some examples:
    (1) Say on my VMC I'm using a long gang fixture between my A axis and center and a tool length over 6 inches would crash into
    my setup. I would use G116T1P2L-6 My program would check T1's length before the tool change and issue an error if the tool
    length was over 6" long. (Crash proof!)
    (2) Say I'm using a drill with a point angle of 130° and want to drill a hole (at full dia) .5 deep with a tall part in a
    chuck or vice right below the tool change position. I would use G116T1P2A130C1 (The drill line: G73R.1Q.1Z-.5-VC8F.003)
    OM6
    VC8=0
    IF[PC EQ EMPTY]NL0
    G16H0Z17.6949
    IF[PC EQ 2]NC2
    G16H0X-20Y-2.5307
    GOTO NL0
    NC2 G16H0X11Y-2.5307
    NL0 IF[PL EQ EMPTY]NQ1
    IF[PL LT 0]NL2
    IF[PL LT VTOFH[PT]]NQ1
    VUACM[1]='TOOL TOO SHORT!'
    VDOUT[992]=1
    NL2 IF[VTOFH[PT] LT ABS[PL]]NQ1
    VUACM[1]='TOOL TOO LONG!'
    VDOUT[992]=1
    NQ1 IF[VTLCN EQ PT]NQ4
    IF[VNTOL EQ PT]NQ3
    IF[VNTOL EQ 0]NQ2
    M64
    NQ2 T[PT]M6
    GOTO NQ4
    NQ3 M6
    NQ4 IF[VNTOL EQ PP]NQ6
    IF[VNTOL EQ 0]NQ5
    IF[PP EQ EMPTY]NQ6
    M64
    NQ5 T[PP]
    NQ6 IF[PA EQ EMPTY]NEND
    IF[VTOFD[VTLCN] NE 0]NQ7
    VUACM[1]='TRC NOT SET!'
    VDOUT[992]=1
    NQ7 IF[PA LT 60]NQ8
    IF[PA LE 180]NQ9
    NQ7 VUACM[1]='ANGLE ERROR!'
    VDOUT[992]=1
    NQ9 VC8=DROUND[VTOFD[VTLCN]/[TAN[PA/2]]]
    NEND G56H[VTLCN] (Activates tool length comp automatically)
    G62X0Y0Z0 (Cancels mirror image automatically)
    G95M54D0
    IF[VC9 LE 1.6]NQ12
    VC9=1
    NQ10 IF[PL EQ EMPTY]NQ12
    IF[PL LT 0]NQ11
    IF[PL LT VTOFH[VTLCN]]NQ12
    VDOUT[992]=1
    NQ12 RTS
    Mar 2009
    1982
    it is a philosophy problem in my opinion. Okuma tool change is simple as selecting the tool (plus tool offset) and tool change command. What problems could be with that kind of matter? If you take the same tool with different offset Okuma just changes the offset. What's wrong with that?
  1. fusion 640 registry change
    By mikey B in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-13-2018, 10:07 PM
  2. Okuma MC-4VB tool change variable for active tool
    By stinkfist in forum Post Processors for MC
    Last Post: 12-09-2012, 12:19 AM
  3. Pccy's? Join the registry!
    By BobWarfield in forum Charter Oak Automation Support Forum
    Last Post: 08-28-2009, 05:25 AM
  4. Registry Message
    By SPEEDRE in forum Solidworks
    Last Post: 05-14-2009, 04:14 PM
  5. Saving offsets in the registry
    By chipsahoy in forum Mach Mill
    Last Post: 08-13-2006, 08:39 PM
