587,040 active members*
2,836 visitors online*
IndustryArena Forum > CAM Software > SheetCam > where to set switch offset ?
    Apr 2008
    11
    Where in sheetcam does one set the switch offset value for the floating Z switch on a plasma torch ???
    Nov 2004
    141
    Ther are two places you can set it. For testing, use the 'set post processor variable' function in SheetCam (button with a big V on it). The variable name is 'switchoffset' (without the quotes). Make sure this appears in the process list before any cuts.
    Once you have got the switch offset sety up correctly, go to c:\program files\sheetcam\posts and open the post with a text editor. Near the beginning of the file you will see a line something like this:
    switchoffset =.060
    Set the value to your switch offset.
    Save the post then rename it. This will prevent it getting overwritten if you update your copy of SheetCam.
  1. Radius Offset and Length Offset
    By jim_stoll in forum Dolphin CAD/CAM
    Last Post: 10-15-2010, 01:47 AM
  2. Replies: 2
    Last Post: 05-25-2009, 05:22 PM
  3. limit switch and home switch setup
    By Runner4404spd in forum CNC Machine Related Electronics
    Last Post: 12-15-2005, 02:58 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
