586,409 active members*
3,053 visitors online*
    Mach3 Router Screen.
    As I mentioned last week, I was throwing together a router Screen for Mach3. This should have all the functions needed for a router, without all the extra clutter in the standard mach3 screens. I haven't really tested it, but I think everything is working.
    There is no toolpath on the Run screen. The reason for this is that CPU usage is about 75% lower without the toolpath on the screen, and when your cutting, you're usually looking at the machine, not the screen. This should make this screen run better on slower PC's than the standard screens.
    Unzip all the .png files to Mach3\Bitmaps\Router\ and put the Router.set file in the mach3 folder. It's setup for spindle to use Output 1 and Coolant Output 2.
    Let me know if there are any issues and I'll fix em up.
    http://home.comcast.net/~cncwoodworker/CNC/Mach3/Screens/M3Router.zip
    Also, here's the Real Draw Pro files if anyone wants to modify the Screens (you'll need RealDraw Pro).
    http://home.comcast.net/~cncwoodworker/CNC/Mach3/Screens/M3Router_RealDraw_Pro.zip
    Attached Thumbnails Attached Thumbnails Router_Load.jpg   Router_Run.jpg   Router_Settings.jpg
    Nov 2005
    655
    I don't have a router, but I do like the look of this screen set. Thanks!
    Cheers,
    Jack
    Walking is highly over-rated
    Apr 2005
    438
    Thanks for taking the time to do this. Very nice GUI, will give it a try tomorrow.
    george
    Apr 2006
    3498
    beautiful yet simple...thanks Gerry for sharing ur hardwork...
    Feb 2004
    2337
    Good work Gerry. I recognize that RealDraw flavor about it.
    Being outside the square !!!
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. What do you want in a simple Mach3 router screen?
    By ger21 in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-03-2008, 09:54 PM
  3. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
  4. 6 axis screen of mach3
    By ayhan in forum Mach Software (ArtSoft software)
    Last Post: 02-21-2008, 11:24 AM
  5. Personalizar el screen del Mach3
    By Creisen in forum Spanish
    Last Post: 07-19-2007, 01:30 AM
