586,754 active members*
7,469 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Fanuc Oitb GibbsCAm post
Results 1 to 3 of 3
    Mar 2006
    6
    I am looking for a post processor for the Fanuc Oi-TB control that can be used by GibbsCam.
    Anyone out there have a file you can Email me.
    Travler
    Mar 2006
    158
    Any standard Fanuc turning post should get you close. I use a slightly modified post for an 0TC control and it works fine for me. The issues you will run into are M-codes, which vary by machine manufacturer, and output for milling if your lathe has that capability. If it is milling you need, your reseller is the best resource. Otherwise, PostHaste can be easily configured to output your code correctly.
    Mar 2006
    6
    OK, Can you send me a a file with the post you are using?
