586,144 active members*
3,453 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > GibbsCam trying Machine Sim Mode
    Jul 2008
    Has anyone created a machine sim using the build machine plug in. Ive been trying to create a simple gang tool lathe however I have been having problems when trying to use multiple tools and tool changes. Also when using build machine the units are supposed to be in mm but I'm not sure whether to put everything in mm or to convert for example if I want 12 inches of travel on the Z axis should I put in 12*25.4 or just 12. I have created an MDD file for the machine as well using the MDD editor. Any help will be much appreciated. If it's possible could I get a machine sim file from someone and try to work backwards.
    Thanks.
    Jun 2003
    513
    There are users who have the machine simulation option at the gibbscam message board. You'll get answers over there.
    Do you actually have the option or are you just trying to use the plug-in without it?
  1. Need a postprocessor for gibbscam
    By pgman68 in forum Post Processor Files
    Last Post: 05-22-2020, 05:38 PM
  2. machine sleep mode
    By mcash3000 in forum Fanuc
    Last Post: 11-15-2006, 05:59 PM
  3. GibbsCAM
    By MagTDK in forum Uncategorised CAM Discussion
    Last Post: 09-24-2006, 06:57 PM
  4. Machine in 3 axis durin g112 mode?
    By M-man in forum Fanuc
    Last Post: 07-23-2006, 02:39 AM
  5. GibbsCam 5 axis
    By cadman in forum Uncategorised CAM Discussion
    Last Post: 07-13-2003, 03:05 AM
