586,354 active members*
3,237 visitors online*
    Jul 2008
    11
    Question PROGRAMABLE TAILSTOCK
    HELLO EVERYBODY, I'm trying to program a tailstock but I get the following alarm:
    M78 or M79 or M70 is not finished within 15 sec after command, check solenoid valve, switch position or program condition.
    Actually I do not know what I have to do,
    I appreciate your help
    Thank you
    2932
    Please post your program (at least the section where you are using the tailstock).
    Nov 2004
    3028
    When you send the tailstock out with an M function (as in a program), it needs verification that it has extended to where it is supposed to be. Typically there is a panel on the side of the tailstock facing the operator. Behind this panel are two swtiches for tail stoack back and forward. You need to adjust the forward switch or actuator so the control sees it and verifies your M function.
    George
    Jul 2008
    11
    Thank you, now the tailstock works perfectly. I had to adjust the sensors that are inside the tailstock.
    Mar 2008
    34
    If the proximity switches get to be a pain, I usually shut off the keep relay that controls them. It should be keep relay 8 bit 7. Please check in the blue book on the electrical cabinet door (unless someone has moved it of course), to make certain this is the correct keep relay.
  1. What is a Programable Logic Controller?
    By DrewSmith007 in forum PIC Programing / Design
    Last Post: 01-19-2008, 03:55 PM
  2. WINCNC Programable down force
    By synd00d in forum WinCnc
    Last Post: 03-04-2007, 03:32 AM
  3. Conversion to programable independant heads for Gantry Twin head router table
    By ohallock in forum DIY CNC Router Table Machines
    Last Post: 04-19-2006, 12:20 AM
  4. Retrofit of Mill with programable DRO and power feeds
    By Paraprop in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2005, 07:57 PM
