586,968 active members*
2,986 visitors online*
    Aug 2005
    28
    HELP!! Haas Super Mini Mill
    Hello Forum,
    I was hoping someone could help me in regards to a spindle problem that I am having. The problem occured during the run of my machine's warmup program. While the program was running I opened the door (Setting 51 is set to Off) and the spindle slowed/stopped as always. The problem occurred when I closed the door to resume running the program. I noticed that the spindle did not kick back in to the programmed spindle rate. I also noticed that the spindle will not orientate or lock into position to properly do a tool change. Any help would be appreciated before I have to call Haa$.
    CB
    Jul 2005
    12177
    Have you done my first problem solving approach? Shut the machine down and then power it up again.
    If this does not work I think maybe take the sheetmetal off the head, it is possible the drive belt between the spindle and the encoder has slipped or broken.
    Aug 2005
    28
    Hello Geof...
    I have powered down a couple of times with no success. I will look into your other suggestions. Any idea of the cost if I have the Haas people come out. My maintenance warranty has expired
    Jul 2005
    12177
    Quote Originally Posted by CountBraden View Post
    ...... Any idea of the cost if I have the Haas people come out. My maintenance warranty has expired
    A few hundred if their hourly rate is the same as my Haas supplier. I had the encoder belt replaced on a VF2 and I think it was about $400 to $500.
    Aug 2005
    28
    Ok.. Thanks .. I appreciate the help
  1. Engraving on an Arc using Haas Super Mini MIll
    By chop5280 in forum Haas Mills
    Last Post: 02-25-2015, 09:36 PM
  2. HAAS Super Mini Mill
    By Ford25 in forum Haas Mills
    Last Post: 09-07-2007, 02:01 PM
  3. Super mini mill/coolant tank
    By taylors in forum Haas Mills
    Last Post: 02-20-2007, 02:33 AM
  4. help with super mini mill please
    By daleman in forum Haas Mills
    Last Post: 08-14-2006, 08:32 PM
  5. part for super mini mill
    Last Post: 05-04-2006, 07:03 PM
