I have downloaded the trail version of Mach3, trying to configurate Mach3 to run the Maxnc 5. I do not have a copy of Maxnc 5 manual, not sure the parallel port pin out for Maxnc 5. The Maxnc 5 is running okay with its Max softsoft, but with Mach3, joggin X, both X and Z moves. Jogging Z, Y moves. Jogging Y, Z motor hums but did not move. I have selected Max NC-10 wave drive in Port Setup & Axis Selection. The Step Pin# and Direction Pin# does not seem to make any change. If I do no select Max NC 10 wave drive, none of the axis moves. Any suggestion? Thanks.
