I used V Carve Pro V 4.6 to generate toolpaths for Mach 3. I have my motors set by the calibration utility in Mach 3. So, I go to the part, set the surface as zero and clear the Z by about 1.00". I load the code using a post for Mach 3 ATC inch, click on the cycle start button here's what happens. The Z axis goes into the table, moves to the left and ramps out and into a position approximately neg Y 3.75" , neg X 3.75" , and cuts air ! The really baffling thing is that it only cuts air for about a dozen or so lines of code and then stops and freezes and it will not start again. I did this twice and the second time I got an error message about an improper something or another. Mach 3seems to be working, my motors move, the axis move smooth and quietly. What I don't get is the jumping out and the freeze. Any ideas ?
