586,608 active members*
3,549 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > How To Make A Left Handed Part From A Right Handed Model???
Results 1 to 20 of 20
    Jun 2006
    29
    O.K.....I am trying to be lazy here. I have an intricate part that I make for the drag racing industry. I made my model for right handed people and have written tons of code (Mastercam) that requires 7 fixturing points to complete. I am getting requests for a left handed model. Is there any easy way to make a mirror image part? It seems to me that keeping the Y's the same and reversing the X's would do it. Is there a setting that allows this? Any help would be greatly appreciated.
    4826
    I'm not sure how often it works out well to do mirror image by sign reversal. If it matters to you whether the tool is climb milling or not, then it most likely means that you would want to redo the toolpath directions in CAM. But for hole pattern type positioning, it would probably make sense to use mirror image on the machine.
    Jul 2005
    12177
    If there are no circular interpolation moves and no tool compensation mirroring one axis can work except as Hu points out you finish up doing conventional milling.
    With circulars or tool comp things don't work. At least in my experience.
    Jun 2006
    29
    Excellent points. I hadn't thought of the fact that I would be pushing the cutter rather than dragging it (there goes my surface finishes). I guess there is no easy way of going about this. Thanks.
    Jul 2005
    12177
    Is it not possible to click the "Make Mirror Image" tab in Mastercam?
    Do any CAD/CAM systems have this ability, to pervert a model?
    Jun 2006
    29
    If there is, I can't find it. That would be a powerful tool, wouldn't it? Something that would automatically regenerate all toolpaths to give you mirror image parts. For $15,000, I would expect Mastercam to have something like that.
    Apr 2008
    21
    I agree with the others, using mirror or sign reversal at the machine will give mixed results - I wouldn't, on what's evidently a complex part.
    But Mastercam CAN do this - just not with 1 or 2 mouse clicks. Exact method will vary depending on your version (8, 9, X, X2?), but it's basically, select all entities, Xform, Mirror, X axis. Regen all your toolpaths.
    Then use backplot / verify to see what you have. Hole paths usually come out OK, as do *MOST* pockets. Contours generally retain original offset side, but since the MIRROR command changes the direction of the chain, you may need to reverse each one to have the tool on the correct side of the contour, and retain climb cut direction. Surfaces like flowlines can also change cut or step direction. It takes a little time to go through, but it beats the heck out of starting over!
    As to the question of, should it be easier for $15K? I'll leave that one alone... but it WILL do what you want.
    Ed
    Jul 2005
    12177
    Quote Originally Posted by flashno View Post
    I agree with the others, using mirror or sign reversal at the machine will give mixed results - I wouldn't, on what's evidently a complex part......
    ......But Mastercam CAN do this - just not with 1 or 2 mouse clicks.
    Ed
    I guess it is the $50,000 CAD/CAM packages that do the single click mirroring.
    Apr 2008
    21
    Quote Originally Posted by Geof View Post
    Spoken like a die-hard G-code programmer! Whom I have great respect for, BTW, as an old G-coder myself. But I niether bash nor praise Mastercam, it just happens to be what I know & use now. It is what it is. Just trying to help the original poster, who has M'CAM, just needs some direction.
    Ed
    Jun 2008
    11
    If this is on a Haas, you can just do mirror image on machine and if the operator is familiar with machine I would feel ok about it as long as he was.
    But he will have to mirror part zero also, it is a little tricky, but it does work well.
    Myself, I would mirror it on machine, and it would have to be very complex for me not to. As far as mastercam ..... cant help on the mirror thing.
    Mar 2008
    683
    G52.1 (X or Y) will mirror a part about the axis you want to mirror on fadals. On my super old Tree there's a command to mirror but forget. I have NEVER run across a controller that will not let me mirror g-code without the CAM software. You'll just have to poke around your controller handbook.
    Mar 2008
    44
    mirror programing mastercam
    I dont know what version of mastercam your useing but when i want o make an opposite of somthing ive allready programed i save my orginal to a new file name ( so you dont screw up the org.) and then mirror that geometry about the y-axis. That gives you your opposite part, then i go to the operations menu. you'll notice that all are red X'd out. I then go to each operation that need cutter comp and pick the chains by right clicking , a menu drops down and one of the options is to reverse chains click that. do this for each conture or pocket op. Then go back to the main operations menu and select all and do a regen. If you did it correctly all your cuts should be climb cuts Then repost I hope this makes even a little since.
    and that it helps -Chris
    Aug 2005
    578
    Mastercam will millor anything in about three mouse clicks.
    Transform, mirror...
    Jul 2008
    45
    I use Smartcam, and it is quite easy to mirror. I just group everything, then mirror about the zero, then reverse direction of cutter path. Done.
    Nov 2004
    260
    The simplest thing to do is to run mirror image on the machine and get left handed cutters. This way you will not loose and edits made on the machine by reposting and you will be able to use the production Programs.
    You could charge the customer for the purchase of the cutters.
    Jun 2006
    629
    Torsten,
    Problem with that is mr. operator for gets to change cutters when the turn everything off and Smash. If I tried to charge my customers for an extra set of cutters, they'd be running elsewhere to get their work done!
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    Aug 2003
    5
    In the Haas control go to settings pgm, type in 45 then down arrow. Right cursor will have that line blinking. Write/enter will turn it on and will have Xmirror shown on the monitor. That will mirror X. All you have to do is put the x zero on the opposite side. If I have to have a left and a right hand part. I will put hard stops on the table or use a dowel pin. Then use g54 for left hand of the material, g56 for the right hand of the material. That way I know where everything is. X mirror will work for cutting alum, but for anything else the surface finish will need help.
    Sean
    Mar 2008
    683
    Quote Originally Posted by Torsten View Post
    I've never heard of mirroring a part reversing the spindle direction so you wouldn't need left hand cutters.
    Mar 2010
    Someone have a Permanent Licence Key for SmartCAM Freeform Machining V10 or V11.5?
    I have only a Tenmporary Licence Key. tks
    Jun 2009
    11
    Ed
    Hi 61Sedanman
    with Mastercam x, x2, x3, x4 this works great and is easier than it sounds follow his instructions and U will be happy ..MC will regen the tool paths..almost everything I program is left and right hand
    Tony
  1. RFQ Can anyone make this part?
    By Milt in forum Employment Opportunity
    Last Post: 09-18-2007, 01:34 PM
  2. Best way to make this part
    By skmetal7 in forum MetalWork Discussion
    Last Post: 09-05-2007, 03:19 AM
  3. Can anyone make this part?
    By Milt in forum MetalWork Discussion
    Last Post: 09-02-2007, 01:48 AM
  4. Would any DIYers (in the US) be willing to make a part for me?
    By 11bravo in forum Community Club House
    Last Post: 04-02-2007, 09:04 PM
  5. Replies: 1
    Last Post: 02-02-2005, 07:24 AM
