586,138 active members*
3,542 visitors online*
Thread: Install
    Jun 2008
    Install
    I'm installing 2 cnc machines. 1 mill, 1 lathe, both 3 phase, both have built-in transformers. I have 208V 3-phase in my building. My question is, without having to check proper phasing by trial & error, can I check phasing voltage at the transformer to see if my phasing is properly connected?
    Mar 2007
    137
    Hi
    I dont think so. if your spindle motor goes the wrong way, just change any 2 of the 3 electrical legs.
    Remember, if the machine has a frequency drive for the spindle, the spindle should always go the correct direction, BUT, the coolant pump may be going the wrong direction, so you would still need to change 2 of the legs.
    Good Luck
  1. Install help
    By djmickyg in forum LinuxCNC (formerly EMC2)
    Last Post: 12-02-2007, 03:05 PM
  2. How to install EMC2
    By cut more in forum LinuxCNC (formerly EMC2)
    Last Post: 07-18-2007, 02:19 PM
  3. EMC Install
    By jhwatts in forum LinuxCNC (formerly EMC2)
    Last Post: 01-10-2006, 12:36 AM
  4. Install Problem
    By crow in forum Uncategorised CAM Discussion
    Last Post: 02-18-2005, 05:43 PM
  5. Turbo Cad/Cam install help
    By Moondog in forum Uncategorised CAM Discussion
    Last Post: 07-28-2004, 08:07 PM
