587,035 active members*
2,854 visitors online*
    May 2006
    83
    Red face BPT R2G4 Fanuc 11MA Crash
    Thanks for looking at my mishap. I was goind a simple G83 Drill Cycle when I crashed do to changing Tool Numbers for unity and forgeting to update the tool length register. Ops!
    So I ramed a small drill into my fixture plate and heard the spindle labor some.
    A simple fix, new drill and ( Now I have no % rapid override") Nothing else was changed and I even shut down and restarted. Still no, rapid override. Makes it a little difficult to step through a program.
    Can anyone see an obvious thing that I have overlooked?
    Lee
    May 2006
    83
    I found the problem.
    The 4 position % over ride switch ended up being a 5 position switch. I am not sure if I did this when I reacted to the crash or not.
    I found the area of the ladder diagram that shows the logic of the switch. At first cycling through the switch positions did not cause the logic to change. Then after I had the panel apart and mess around I could see the hi low signals changing. This is when I found the extra position. Ended up that I had 100% at both extreams of the switch.
    It's working now.
    Mar 2008
    Re: BPT R2G4 Fanuc 11MA Crash
    Looking for R2G4 Electrical Schematics.... anyone?
  1. fanuc ot- m code crash
    By Jdmmk3 in forum Fanuc
    Last Post: 02-18-2013, 11:20 PM
  2. Fanuc 0i-mc tool crash
    By motordude in forum Fanuc
    Last Post: 05-14-2011, 11:54 AM
  3. Bridgeport R2G4 with Fanuc 11MA
    By leeputman in forum Bridgeport / Hardinge Mills
    Last Post: 09-15-2009, 12:28 PM
  4. Replies: 9
    Last Post: 04-28-2008, 06:10 PM
