586,523 active members*
3,289 visitors online*
IndustryArena Forum > CNC Electronics > UHU Servo Controllers > Old Regular UHU (for 60V to 80V and less)
Page 3 of 5 12345
Results 41 to 60 of 91
  1. #41
    Aug 2006
    2758
    Quote Originally Posted by per.e View Post
    Thanks for your reply kreutz.
    It is MAX232CPE chips with 10u caps around it.
    I will change the caps (10u-0.1u) to se if that was the problem for me.
    Best regards:
    Per
    The capacitors should be 1 uF/ 16 - 25Volt for that chip. Observe polarity.
    Best regards,
    Kreutz.
  2. #42
    1050
    Also Think Tantalum's would help
  3. #43
    Feb 2005
    32
    Ihave tantalums 10u in there.
    I am no expert in electronics so be cind to me.
    Is it good with electrolyts and shold i change only C10,C11,C12 & C5 or should i even change the 5 one below the four ones between MAX232 and the D-sub ?
    Per
  4. #44
    Aug 2006
    2758
    Per
    You can also use electrolytic capacitors, although I prefer tantalum for that job. 10 uF are not a good choice for that chip.
    Best regards,
    Kreutz.
  5. #45
    Feb 2005
    32
    So Mr kreutz i should use 1uF Tantalium for the four caps C10,C11,C12 & C5 ?
    I will replace them tomorrow and let you know if that was the problem.
    Per
  6. #46
    Feb 2005
    32
    "Huston, we have contact"
    Replacing the four caps from 10uF Tantalium to 1uF Electrolyt did it so i made contact with the UHU chip.
    But there is only ~-6.5V from MAX232 to TL082 chip, could that be a problem and can it be better with 1uF Tantalium caps ?
    I found the 4 Electrolyt caps here at home and i only wanted to test with them.
    Per
  7. #47
    Aug 2006
    2758
    Per
    The voltage is probably going to rise a little, due to the tantalum capacitors having less leakage, but -6.5V is OK.
    Congratulations!
    Kreutz.
  8. #48
    Feb 2005
    32
    It is thanks for you kreutz that i managed to do this. :cheers:
    This is my first PCB that i ever made and i am 47 years old
    Best regards:
    Per
  9. #49
    1050
    Good - now move on fast -
  10. #50
    Sep 2006
    20
    how to protect driver IR2184
    I have tested old UHU with various motors and several times I blown mosfet drivers. First I tried with 12V zener diode, but without succes. Later, I have used P6KE15A, but controller doesn't work !! When I removed P6KE15A it works.
    What is right solution to protect drivers.
  11. #51
    Jan 2006
    297
    Kodalo,
    It sounds as though your installing the P6KE15A with the polarity reversed, turn around in the circuit ............
    Paul
  12. #52
    Sep 2006
    20
    Quote Originally Posted by tenmetalman View Post
    Kodalo,
    Paul
    I have installed zener diode with same polarity direction and it works.
  13. #53
    May 2006
    161
    What MOSFETs are you using? In most cases the FETs have internal diodes but they are quite slow and the switching spikes are more obvious. With the external diodes the signal has a better shape.
    Todor
  14. #54
    Sep 2006
    20
    Quote Originally Posted by LZ1TWB View Post
    Todor
    I am using IRF450. Since I have plans to work with higher voltage (~90 V) I think is better to start using HP_UHU. Is there any usefull PCB? I have found UHU rev1.0b.rar and UHU_MODIFIED_Dated1.4.08_R1.0b.pdf inside, but there is no acceptable print layout - I must resize, convert to black.... Any other solutions are also welcome - good PCB, getting bare board...
  15. #55
    May 2008
    10
    anyone have any problem with hpcl 2231, cause my servo motor turn only at one direction , the signal from the computer is good but why my servo turn only at one direction ?
  16. #56
    Sep 2006
    20
    Quote Originally Posted by nuai View Post
    Check MOSFETs. I have similar problem and one MOSFET was wrong.
  17. #57
    Feb 2008
    553
    Hello everybody,
    I've been away from this project for too long, i was going to assemble my first board when i read "0,6mm silver wire is used for jumpers" so my questions are:
    1) is it possible to replace the silver wire with 0.6mm copper wire from telephone line ?
    2) why is the silver wire used & what limitations/troubles can result from the use of copper wire instead ?
    3) if it's critical, where can i source silver wire & what kind of shops usually sell it ?
    EDIT:
    Ok guys, i agree that this was a stupid one, but i'm really lacking knowledge...so... help is needed please !
    Thanks !
    cnc2.
  18. #58
    Jan 2006
    297
    silver vis copper wire for jumpers on drive PCB
    CNC2,
    Never a dumb question, I ask when something bothers me. that's one of the nice things about CNCZONE & all of the good people out there.
    use what ever wire is handy ! I generally save some leads I snipped off resistors and use those for jumpers. they work just fine
    Paul
  19. #59
    Feb 2008
    553
    Thanks for the reply Paul !
    Yea man the zone is great for that, i agree.
    Thanks for the tip, i'll go looking for the leads remaining from previous projects.
    Did you run your boards yet ?
    Thanks !
    cnc2.
  20. #60
    Feb 2008
    553
    I just soldered the jumpers & saw that the soldering iron was burning the flux from the solder on thin tracks, making it hard to get a clean stuff...
    What kind of soldering iron are you guys using ?
    (i'm using a cheap 40W soldering iron)
    Is there a way to get it done by pluging the soldering iron into a light dimmer ?
    Thanks !
    cnc2.
Page 3 of 5 12345
  1. Replaced regular threaded rod with ACME leadscrew
    By jeffmorris in forum DIY CNC Router Table Machines
    Last Post: 06-06-2008, 08:36 PM
  2. What's the different between a CNC Swiss Lathe and a regular CNC lathe?
    By squale in forum Uncategorised MetalWorking Machines
    Last Post: 11-09-2007, 04:54 PM
