586,410 active members*
3,322 visitors online*
IndustryArena Forum > CNC Electronics > UHU Servo Controllers > High Power UHU Thread (HP.UHU)
Page 1 of 4 123
Results 1 to 20 of 62
    1050
    Hi Folks,
    Just thought the we have different threads under the UHU thread so here it is.
    The HP UHU thread
    Mar 2008
    20
    hello to all,
    just been testing my board with motor and power for the first time,
    no smoke yet! but i can't get the motor to stabilise.
    when i switch the motor power on, the motor starts to run,if i do a reset the motor stops, then when i turn the shaft i can feel strong torque in one direction,but then the motor runs in opposite direction.
    after 3 hrs of adjusting the p.i.d the closest i have come,is to have the
    shaft stationary,but only torque in one direction.
    The motor power 40v.
    motor 70v 5amps with standard encoder conected to PINS A-6 B-4 ON J4.
    JUST SPOTTED! SHOULD BE =A pin 5 ,B PIN 3.
    is this my problem or is there something else.
    can you please help. Regards, Mick.
    Nov 2006
    70
    Quote Originally Posted by mick22 View Post
    hello to all,
    Hi Mick,
    as far as I remember I had also some problem using HEDS standard encoder with the SN75115N differential encoder, so I simple took it out an I put two wire 'jumper' into the Ic shocket for the A and B signal...
    And please check the old thred :
    http://www.cnczone.com/forums/showth...14217&page=158
    especially : #1890 05-01-2008, 06:14 AM tenmetalman
    the partlists includes the latest changes regarding values some component...
    I hope that helps ...Best regards,
    Jozsef
    Mar 2008
    20
    Quote Originally Posted by HJozsi View Post
    Hi Mick,
    Jozsef
    Jozsef,
    thanks for your reply,
    i tried removing the SN75115N and fitting jumpers,but still can't get
    the shaft stationary with torque in both directions.
    regards,
    mick.
    Jul 2007
    887
    Hi Mick,
    You say you have torque in one direction only. Is it completely "dead" in the other direction or do you have "some" torque but not as much as in the first direction?
    I ask because I've expereinced both problems... ;-) At first I had no torque at all in one direction, this turned out to be a fabrication error on the PCB which resulted in the gate-drive signals being shorted to ground for one of the MOSFETs. There's more info in the old thread.
    Then I had the problem with different torque depending on direction and this was cuased by the current limit circuit triggering due to noice, increasing C29 from 100pF to 470pF cured it on my test drive.
    If you have a scope, look at the PWM output from the UHU-processor to see if it "tries" to apply torque in both directions, then look at the outputs from both IR21844 driver chips and see if you have drive signals to the MOSFETs.
    HTH
    /Henrik.
    Mar 2008
    20
    Quote Originally Posted by H.O View Post
    Hi Mick,
    HTH
    /Henrik.
    hello Henrik,
    no it is not completely dead, infact it is possible to get torque in
    both directions,but not when the settings have been adjusted to make the
    rotor stop after a reset.
    i have had a situation where reseting toggles the direction of rotation.
    no i dont have a scope.
    thanks, mick
    Henrik,
    there are no step and dir signals connected yet,could this have
    anything to do with it.
    regards.
    1050
    are you using the Gxxx for moving the motor, then even I find that sometimes the motor does not move, I think its programmed to behave that way!
    well try connecting the step and direction signals and the motor will turn.
    RGDS
    Irfan
    Mar 2008
    20
    Quote Originally Posted by contactirfu View Post
    RGDS
    Irfan
    thanks Irfan,
    my problem is getting the rotor to stop, with torque in both
    directions.
    regards, mick.
    Aug 2006
    2758
    thanks Irfan,
    directions.
    regards, mick.
    Hello;
    If the rotor moves in the wrong direction when applying torque, you should reverse the motor cables. If it oscillates around the rest position you should work on the motor tuning (PID). If it moves in both directions but does not stop, it is getting noise on the step/dir signals, there is a problem with the encoder signals, or there is a problem with the output stage Mosfet driving, as pointed out by Henrik.
    Kreutz.
    Mar 2008
    20
    Quote Originally Posted by kreutz View Post
    Hello;
    Kreutz.
    Kreutz,
    many thanks for pointing me in the right direction,
    all i have to do now is find the courage to mess with the board.
    cheers, mick.
    Mar 2008
    20
    Hello to all,
    after my partial success with this board i have smoked the
    output , luck'ily the board is ok, now i'm back to reading the old posts.
    could someone please tell me, how important is height of R37,R36,R29 &R23
    above the board surface, mine are way below .15",could this be my trouble.?
    regards mick.
    ps
    i'm now the proud owner of a scope,so maybe will be able to stop the smoke!,
    Nov 2006
    70
    Wink
    regards mick.
    Hi Mick,
    regarding my experience, it is more important the proper current limit...
    regards,
    Jozsi
    Mar 2008
    20
    Hi Mick,
    regards,
    Jozsi
    thanks Jozsi,
    Aug 2006
    2758
    Hello to all,
    regards mick.
    ps
    Those resistors will heat-up under normal working conditions, so keeping them about 0.15" from the PCB surface will accomplish two things: avoid PCB over-heating and degradation with time, and avoid arching to the ground plane.
    Other resistors that should be kept at least 0.15" from the PCB surface are: R24, R27, R31, R34 (22 ohm gate resistors) just to comply with creepage distances (the ones in bold are more important).
    Kreutz.
    Mar 2008
    20
    Kreutz,
    thanks for the reply.
    mick.
    1050
    Me and paul are planning to have few more kits (limited) ready by mid August, interested folks may email uhu.highpower(at)gmail(dot)com,
    the new kits have C19 and C23 tantalums caps rated at 35Vs, and the 0.1uF ceramics are replaced by all mylar caps.
    it still stands beta!
    Jan 2006
    297
    Current state of HP UHU Drive, Parts & Build
    Hello All,
    the following is a recap of information I sent to John D. earlier.
    Be sure and read the trials Irfanulla & I've gone through and take advantage of his learning curve. To avoid seemingly random catastrophic drive failures be sure to build and use the Regenerative Power Dump & install the 4700uF electro 50vdc Cap & 1uF 50vdc caps in parallel with 15volt power supply. Also use 10uF 35vdc tantalum caps on C-19 &C-23 on the HP UHU drive. I can see I've fallen way behind on updating the parts list & build recommendations. We are still building on the Rev. "B" PCB. All need to be Building to Rev. "C" Parts plus the above special instructions. Driving servo's of over 100vdc & 10 amps WILL result in the above catastrophic failures, UNLESS ALL of the listed changes are implemented the failures will occur & appear random & will end up damaging all of your HP UHU drives. the RPD PCB's are fairly easy to make.
    Good Luck to All
    Paul
    Mar 2008
    20
    Hello everyone,
    just got my board up and running ,after blowing the output.
    Before i test with motor power 38v,would it be possible for someone to
    post the waveforms that should be present on the HI and LO pins on
    the IR21844 drivers, on a good board.
    i have looked at them with my scope and there is a slight difference between
    them,BUT i dont know what i'm looking at!.
    also is the power dump board needed with this low voltage ?,because i
    don't know why the output blew in first place.
    thanks everyone,
    mick.
    1050
    power dump circuit I feel is not needed for such low voltages . I think.
    this time chk if the tantalums are rated for 35v, the 25v tantalums generated so much heat when burnt that they burned a hold in the UHU pcb.
    Aug 2006
    2758
    First tests after successful assembly
    Check all the connections, measure resistance across 15V terminals, Motor power supply terminals and motor terminals, no short circuit should be present.
    Connect the encoder cable (with the pins 8 and 2 jumpered on the encoder side), RS232 cable to PC, USB cable to PC, and 15 Volt power supply. Connect the motor terminals to the right connector, but don't power on the motor power supply for this test. Do not insert the UHU chip on its socket yet.
    Turn on the 15 V power supply and check the 5 volts between the 15V power supply GND terminal and pin 10 of the UHU chip socket. If OK, turn off the 15 V power supply and wait about 10 seconds for the voltage to drop to zero, then insert the UHu chip on the socket
    Start the UHU communication terminal software on the PC and turn on the 15V power supply. You should have the UHU information and menu screens on the terminal screen. power ON and Firmware Ready LEDs should be ON.
    Program the PID and H parameters, maximum error set to 2000
    Turn the motor shaft by hand several turns, the Tracking Error LED should turn ON.
    Reset the UHU chip in order to reset the error state.
    Turn the motor shaft again in the opposite direction, it should be exactly the same, you have tested the encoder circuit as well as the UHU chip interface. Turn off the 15V power supply.
    Connect the Step and Direction pins to the BOB, connect the BOB to the PC, start Mach3.
    Connect a 24 to 36 V power supply cables (12 V batteries in series will work) to the motor voltage terminal observing the right polarity (DON'T POWER IT UP YET!!). Turn on the 15v power supply, turn on the motor power supply after a few seconds. Nothing should burn, heat-up or smoke.
    Turn the motor shaft by hand, the shaft should try to turn back to the original position and should exert some resistance. If it continues to turn in the same direction as the manual push and the tracking Error LED lights up, shut down the motor power supply first, then turn off the 15V power supply after a few seconds. Reverse the cable connection on the motor terminals. Repeat the test. Nothing should be hot, or smoke. Command some movements by means of the terminal software, beware, the step size should be less than the 2000 figure you setted up for the encoder error count parameter.
    If everything went OK, you are ready to begin some serious testing at the required motor voltage.
    The USB cable should be connected during the tests and during the PID tuning, its function is to provide 5 volts to the isolated PC serial interface. Without that connection you won't have serial communication with the PC.
    15V SHOULD BE PRESENT ON THE BOARD EITHER BEFORE OR SIMULTANEOUSLY WITH APPLICATION OF THE MOTOR POWER VOLTAGE, OTHERWISE THE BOARD WILL BE DAMAGED.
Page 1 of 4 123
  1. High power UHU
    By bolttjza in forum UHU Servo Controllers
    Last Post: 04-01-2010, 03:45 AM
  2. Clausing Colchester Repair/ high speed thread attachment
    By naytep in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-23-2009, 01:02 PM
  3. Need method to apply thread Lubricant (high volume assembly)
    By rkremser in forum Mechanical Calculations/Engineering Design
    Last Post: 08-20-2009, 11:19 AM
  4. High voltage & high power servo drive design
    By Xerxes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-23-2008, 03:24 AM
  5. Replies: 7
    Last Post: 04-15-2008, 10:27 AM
