586,504 active members*
3,366 visitors online*
IndustryArena Forum > CNC Electronics > UHU Servo Controllers > High Power UHU Thread (HP.UHU)
Page 2 of 4 1234
Results 21 to 40 of 62
  1. #21
    Mar 2008
    20
    Quote Originally Posted by contactirfu View Post
    power dump circuit I feel is not needed for such low voltages . I think.
    this time chk if the tantalums are rated for 35v, the 25v tantalums generated so much heat when burnt that they burned a hold in the UHU pcb.
    Thanks IRFAN,
    i did have that problem,but escaped without damage to the
    board,the caps just exploded and left a dirty mess.
    rgds mick.
  2. #22
    Aug 2006
    2758
    Quote Originally Posted by mick22 View Post
    Hello everyone,
    just got my board up and running ,after blowing the output.
    Before i test with motor power 38v,would it be possible for someone to
    post the waveforms that should be present on the HI and LO pins on
    the IR21844 drivers, on a good board.
    i have looked at them with my scope and there is a slight difference between
    them,BUT i dont know what i'm looking at!.
    also is the power dump board needed with this low voltage ?,because i
    don't know why the output blew in first place.
    thanks everyone,
    mick.
    You should not measure the waveform on those pins, they are the gate drive outputs, have different reference potential, and it could be as high as the motor power supply voltage + 15V for the HO pins. Look at the waveforms I posted on the original UHU thread while troubleshooting the overheating snubber issue.
    If you want to see the driver waveform look at U7 pin 1 and U8 pin 1 respectively, they should be measured with reference to P3 (GND test point), they will be 23.5 khz pulses U8 pin 1 inverted regarding U7 pin 1 waveform.
  3. #23
    Mar 2008
    20
    Happiness
    Hello from a very happy old man,
    Thanks to the guidence and advice from this
    forum i've just finished a totally successful test on my first hp-uhu
    board.
    thanks everybody.
    mick.
  4. #24
    1050
    HI Mick,
    We should thank you and many others for taking up and trusting this relatively new design. Do elaborate on the tests you have done and the parameters you have set.
    RGDS
    IRfan
  5. #25
    1050
    A look at the kit -
    Thank you Paul for the Picture.
    RGDS
    Irfan
  6. #26
    Mar 2008
    20
    HI Mick,
    RGDS
    IRfan
    Irfan,
    i was hoping to upgrade my power supply to around 100 volts
    before posting a reply but hav'nt managed it yet,
    [/LEFT]The only parameters altered from the defaults are H 4000 and E 30,
    the 70 volt motor has massive torque in both directions.
    The only testing done was with a small Gcode subrutine varying speed
    and distance, this was running for about an hour,no o counts.
    The standard encoder 200 cpr is connected with the SN75115 removed
    and jumpers from the socket to j1 j2
    MACH3 is running at 25 kc,steps per mm 630, velocity 2164 mm the
    acceleration was lowered until there was no error tripping.
    rgds mick.
  7. #27
    Jul 2008
    35
    Is there a schematic available somewhere for the "power dump" circuit ?
  8. #28
    1050
    Quote Originally Posted by Scott Kelley View Post
    yup on the old UHU thread.
  9. #29
    Jul 2007
    887
    You can find it in this post
    /Henrik.
  10. #30
    Mar 2008
    20
    Hello,
    I have just blown the output on my hp-uhu board,after weeks of being
    meticulous, switching the logic first and then the power.
    i connected both logic and power to the same toriod and BANG.
    when the irf264's and thier drivers have been replaced what else
    should i replace.
    thanks.
    mick.
  11. #31
    1050
    can we have pictures mick.
    rdgs
    Irfan
  12. #32
    Aug 2006
    2758
    Hello,
    should i replace.
    thanks.
    mick.
    Just replace the drivers and the Mosfets, check the gate resistors also. Please, post a photo. Paul had a similar issue in the past.
    Best regards,
    Kreutz.
  13. #33
    Mar 2008
    20
    Irfan,Kreutz,
    Thanks for coming back,here are 3 shots of the damaged board.
    hope you can see the burnt track around Q4, I hope to repair
    this with copper wire hammerd flat.
    this is the third time the mosfets have been replaced,and the
    board is starting to look iffy!,already the small tracks to Q2 are
    replaced with wire.
    so i think just one more try before the Z axis on my lathe goes
    back to steppers.
    thanks for all the help and advice,
    rgds mick.Click image for larger version.
  14. #34
    Jul 2007
    887
    Hi Mick,
    I'm sorry to hear you've blown the MOSFETs.... You said you connected both logic and power to the same toriod. What exactly did you mean by that?
    I'm not sure exactly what the UHU-chip does during "boot up" but you really should have the logic part powered up before applying the motor power supply.
    The other times this happend, was it with the same motor, perhaps you have short in that motor...
    /Henrik.
  15. #35
    Aug 2006
    2758
    Irfan,Kreutz,
    replaced with wire.
    back to steppers.
    Is this one the only board with that problem?, Do you have other HP_UHU boards?
    Maybe there is a defective component on the dead-time circuit (100K resistors) going from pin4 of the Mosfet drivers to GND. check also R22 and R28 (10 ohm) and D4 and D5. Check the PCB traces too.
    Best regards,
    Kreutz.
  16. #36
    Mar 2008
    20
    Hello Henrik,
    The first time the mosfets blew was due to my ignorance,
    not switching logic on first.
    2nd time the 15v supply and powerside were wired from the
    the same socket,i thought they would both come on together,
    the drive worked until it was switched of,but the next time it
    was turned on there was smoke!.
    after the repairs i went back to manual switching logic and then
    power,for weeks the z axis on my lathe ran ok.
    but then i got hold of a toroid able to supply 70v ac there is
    also a winding 12v ac which i used for the 15vdc supply,
    the results were tragic,
    if and when the board is ok after repairs,is there need to
    fit a delay off timer to the logic supply as well as a delay on
    timer to the power side.
    rgds, mick.
  17. #37
    Jul 2007
    887
    Hi Mick,
    I really can't tell you what is strictly neccessary. All I can tell you is what I've done: I have my motor powersupply switched on and off by a large contactor, this contactor is controlled by the E-stop circuit which gets its power from the low voltage powersupply. So, I can't turn on the motor power supply if the low voltage power supply isn't already on.
    When I E-stop the system the contactor switching the motor power supply switches in a resistor across the capacitor bank that discharges it around 1.5second.
    Obviously, if I get a power failure both the low voltage supply and the motor power supply will be switched off at the same time - I have no idea what happens then.... :-/ Hopefully there's enough capacitance in the logic supply to keep the drive alive long enough to prevent terminal damage....
    Again, I've never had any problems like this myself but judging from others it seems it's a bit too sensitive this power sequencing thing :-/
    I hope you can get it going again!
    /Henrik.
  18. #38
    Mar 2008
    20
    cheers Henrik,
    mick.
  19. #39
    Aug 2006
    2758
    Merry Christmas!!
    Kreutz.
  20. #40
    Aug 2006
    2758
    Re: High Power UHU Thread (HP.UHU)
    Hello;
    It's being a long time and in a last few days I have been exchanging e-mails with Henrik (H.O.). He has been involved in this little project since the beginning and I really appreciate his contributions, creativity and knowledge.
    Resulting from our e-mail exchange is a modification to the HP-UHU current limit circuit that will make it a lot more reliable. The modification includes only an extra diode (1n4148) and resistor (2.2k 1/8W), as well as desoldering one lead from another resistor and reroute +15V to that lead. Integrator Capacitor (C28) should be a film capacitor rated at 25V or more.
    Enjoy!!
    kreutz
Page 2 of 4 1234
  1. High power UHU
    By bolttjza in forum UHU Servo Controllers
    Last Post: 04-01-2010, 03:45 AM
  2. Clausing Colchester Repair/ high speed thread attachment
    By naytep in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 09-23-2009, 01:02 PM
  3. Need method to apply thread Lubricant (high volume assembly)
    By rkremser in forum Mechanical Calculations/Engineering Design
    Last Post: 08-20-2009, 11:19 AM
  4. High voltage & high power servo drive design
    By Xerxes in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-23-2008, 03:24 AM
  5. Replies: 7
    Last Post: 04-15-2008, 10:27 AM
