586,103 active members*
3,028 visitors online*
IndustryArena Forum > CAM Software > Surfcam > 4th Axis helical cut
    May 2007
    24
    Hello Group,
    I am trying to help our programmer at work on how to generate the g-code to cope the end of a 6" pipe for a "T" joint. We need to roughcut the end on a rotary 1st. The shape of the pipe end if the pipe was split and layed out flat would be a sine wave shape. Do we need to model surfaces, or just a 3-D spline around the pipe.
    Thanks in advance,
    Pat
    Sep 2004
    264
    You could program the sine wave (unrolled end profile) as a 2D contour operation and then from the Ops manager use Transform>Wrap Cylinder to wrap the toolpath back around the pipe and output that with a 4-axis post...
    Although it seems to me it shouldn't be too hard to find a cutter with a 3"+ flute length and do the op on the rotary in two halves as two straight line cuts, turning the pipe over between... --ch
    May 2007
    24
    Thank you for the reply,
    I guess we need to make sure we have a 4th axis post which I assume we have as we have done some rotary work.
    There are many ways to do this job and we even thought about waterjet cutting the part.
    Thanks again,
    Pat
  1. Helical Boring Help
    By Blosser5 in forum MetalWork Discussion
    Last Post: 11-30-2007, 03:03 AM
  2. Helical Milling
    By binzer in forum GibbsCAM
    Last Post: 03-30-2007, 10:39 PM
  3. Helical Machining?
    By tnik in forum Surfcam
    Last Post: 03-15-2007, 02:00 PM
  4. helical milling
    By hogman in forum GibbsCAM
    Last Post: 04-22-2006, 02:15 AM
  5. G2/g3 Helical In Yz(g19)
    By leggetmachine in forum G-Code Programing
    Last Post: 03-23-2006, 05:48 AM
