587,045 active members*
3,096 visitors online*
IndustryArena Forum > CAM Software > SheetCam > Post proccessor for Fanuc Oi-MC
Results 1 to 7 of 7
    Apr 2007
    148
    I have modified one of the post proccessors to work with my fanuc Oi-MC control, does rigid tapping and all the good stuff. Would like to post it here, Les, if your out there do you mind if I post it so others can use it? Thanks in advance.
    Nov 2004
    141
    No problem. Do you mind if I include it in the SheetCam installer?
    Thanks,
    Les
    Apr 2007
    148
    Quote Originally Posted by locost_cam View Post
    Thanks,
    Les
    No, not at all. I think it would be a great idea to have a Fanuc post proccessor that others can use. Here is the file. One note, when it posts the work coordinate system will come out as G? instead of G54-G59. This allows the programmer to do a find and replace so that the programmer can chose the work coordinate system based on how he/she wants to handle multiple work offsets. Also I added to, and rearranged the safety lines to play nice with the Fanuc oi-mc. I converted it to a txt file so that I could upload it, you may need to change the extension back to .post in order for it to work. I hope this will help others to use Sheet Cam, it really is great software.
    Attached Files Attached Files
    Nov 2004
    141
    Thanks. Are the G0 Z1 moves just to go to a safe height? If so, I'll change them to be compatible with metric as well as inch. I'll also do a few other minor tweaks and upload it for you to try.
    Thanks,
    Les
    Apr 2007
    148
    Thanks,
    Les
    Yes the G00 Z1.0 is a safe height move, I use it to verify correct tool length offset when running at 25% rapid speed.
    Mar 2006
    6
    HI,
    Could you send me a copy of the FANUC oi-MC post file?
    I can not seem to down load it off the CNC Zone site.
    AL
    [email protected]
    Aug 2014
    2
    Re: Post proccessor for Fanuc Oi-MC
    i need post proccesors for fanuc Oi-MC control ??? who can share for me???
  1. Replies: 1
    Last Post: 01-03-2017, 04:23 AM
  2. Cutter Comp error with post proccessor
    By Harley95 in forum FeatureCAM CAD/CAM
    Last Post: 03-04-2014, 02:09 PM
  3. Sheetcam TNG Post proccessor for HPGL export
    By LazyBee in forum SheetCam
    Last Post: 09-06-2009, 05:28 PM
  4. Flashcut Post Proccessor
    By whiteriver in forum FlashCut CNC
    Last Post: 04-20-2008, 11:15 AM
