I have a cnc machine with this motor..(STP-MTR-23079) from automation direct. Its a NEMA23, Bipolar.
The gecko drive died. I replaced the gecko drive controller and now the fuse from the power supply to the gecko for this motor blows only with the motor connected. If I disconnect the motor and power up the system the fuse does not blow. If I connect an older motor that was replaced previously the fuse (5amp ceramic) still does not blow.
Is there a way to check this newer motor for an internal short with a multi-meter? I wonder if something to it when the gecko blew; or is this motor what killed the old gecko drive.....
Thanks in advance!
Dennis
