587,047 active members*
2,695 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Multiple pulses for spindle encoder - how to install?
    Feb 2008
    19
    Hi
    I have a single pulse per rev tacho on my spindle (Mach 3, ver 2.63) which works nicely. I wish to add more pulses per revolution but I cannot see where I tell Mach 3 how many index pulses there are per revolution. Is there an easy way to add this?
    Thanks!
    Why do you want to add more? From what I've read, one pulse per rev works fine and is what's recommended.
    Feb 2008
    19
    I wanted a smoother reading of the rpm at low speeds - eg at 200 rpm there are only three pulses per second so the control tends to be a bit jerky. It mentions in the UsingMach3 pdf that "The index sensor can generate severla pulses per revolution.." on page 6-5 but there is no info on how I set this in the software
    Thanks!
  1. Spindle encoder
    By Mark Hockett in forum Fadal
    Last Post: 03-17-2008, 09:27 PM
  2. spindle encoder belt
    By RICKG in forum Fanuc
    Last Post: 10-23-2007, 12:14 AM
  3. spindle encoder
    By heilcnc in forum LinuxCNC (formerly EMC2)
    Last Post: 09-10-2007, 03:12 PM
  4. Multiple spindle or CNC? with wobble broach capabilities
    By Speedlox in forum Mechanical Calculations/Engineering Design
    Last Post: 07-23-2006, 05:05 PM
