586,533 active members*
2,887 visitors online*
    Jun 2008
    Haas TM2 Leaking Coolant
    My TM2 is leaking coolant out the back of the machine, and I know this problem has been brought up in other posts as a common issue.
    What ideas have people tried that successfully held back the tide?
    Dec 2005
    439
    im not to sure about this problem but I know the Mini Mills have a lot of issues. A good indoor out door sealant and for the larger holes put in chunks or closed cell foam.
    Good luck with fixing the holes coolant leaks are never fun
    I'm not lazy..., I'm efficient!
    HAAS GR-408
  1. HAAS VF-6 Thru Spindle Coolant
    By kwhizz in forum Haas Mills
    Last Post: 04-12-2008, 02:46 AM
  2. thru spindle coolant leaking
    By GARY DAVIS in forum Fadal
    Last Post: 03-25-2008, 01:28 PM
  3. Coolant leaking slowly on back of VF3
    By Rocko1 in forum Haas Mills
    Last Post: 12-07-2007, 12:38 AM
  4. Haas facemilling:coolant yes or no
    By joesimmers in forum Haas Mills
    Last Post: 06-16-2007, 02:23 AM
  5. Haas TL-2 Coolant ?
    By 100 in forum Haas Mills
    Last Post: 04-14-2006, 11:11 PM
