586,217 active members*
3,235 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Y axis moving without being programmed HMB-1
    Apr 2005
    1194
    Its a older HBM-1 control and everytime we try a program the Y axis moves out to its limit without any Y move programmed....what the heck? Anyone have a good direction I can try?
    Feb 2007
    592
    If its creeping then I'd say it was a gain adjustment on the servo amp .
    If the machine just takes off then you have an open connection between the servo encoder and the amp/cpu rack
  1. Trade offs between Moving Gantry and Moving Table
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 04-22-2011, 07:48 PM
  2. Mach3 y axis dc servo jumps when moving small increments only.
    By mif73 in forum Mach Software (ArtSoft software)
    Last Post: 09-15-2008, 09:32 AM
  3. Moving Table vs Moving Gantry; Dremel vs Router
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 03-28-2007, 02:48 AM
  4. Axis are not moving
    By Reef Guy in forum Mach Software (ArtSoft software)
    Last Post: 09-14-2006, 02:42 AM
  5. Need PIC programmed
    By randyf1965 in forum CNC Wood Router Project Log
    Last Post: 03-27-2005, 12:56 AM
