586,076 active members*
3,870 visitors online*
Thread: Milling Foam
    Nov 2007
    151
    Milling Foam
    Does anyone have experience milling foam inserts like the ons found inside pelican cases? I like to cut a few of the inserts (nicely) to fit my camera equipment. Was looking into a foam wire cutter but saw that milling is possible so thought if I can mill foam, it would be even better since I wil have depth control as well instead of cutting all the way though like you have to do wih a wire cutter.
    Any suggestions on type of endmill needed as well as feed/speed?
    Thanks!
    Ken
    Nov 2006
    6
    Milling foam
    We have milled camera case foam with a 1/2 in carbide cutter at full speed with reasonable results. We have a vacuum cleaner on it. We've held the foam in a just press fit plywood jig.
    Have been advised that a carbide burr is what is used commercially.
    Brian Harris
    Nov 2007
    151
    Intersting!! Thanks for the feedback. I'll have to try it. Been wanting to cut some Pelican foam inserts to custom fit some of my guns. Thanks again!
  1. Milling soft cushioning foam?
    By corpseguy in forum CNC Wire Foam Cutter Machines
    Last Post: 02-23-2008, 11:06 PM
  2. Foam & Wood milling machine
    By perolalars in forum DIY CNC Router Table Machines
    Last Post: 04-11-2007, 05:42 PM
  3. endmill specs for foam milling ?
    By max_imum2000 in forum CNC Wire Foam Cutter Machines
    Last Post: 12-28-2006, 10:33 PM
  4. High Speed CMS FOAM 5-axis milling machine
    By fairlane77089 in forum Hard / High Speed Machining
    Last Post: 06-05-2006, 04:09 PM
  5. Milling Foam- Speeds/Feeds
    By JerryFlyGuy in forum Material Machining Solutions
    Last Post: 11-21-2005, 05:02 PM
