586,796 active members*
2,568 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > how to edit edgecam post processor
    Jun 2008
    i have a problem, i have the post processor file for master cam x, how can i edit it to edgecam 12 post processor file? or do i need to make a new post processor file. the machine is FADAL VMC 2016L. thanks for helping.
    Oct 2003
    127
    i don't think you can do that.
    you will need a new one.
    they are fairly easy to work up or modify an existing one if you know what you what your program to look like.
    i have worked up a few for different machines from scratch.
    there are several around at different sites.
    they are kinda specific to your preferences as far as the small details but most will be real close to what you need.
    i have fadal posts if you email me i can give them to you at your own risk.
    i have seen some at most forums i've been to for edgecam, fairly common machine.
    [email protected]
    Jun 2008
    21
    you definately need to make a new one. You can use your last post processor as a guide, most things should be the same, but you need to spend the time to make a new post processor
  1. post processor edit for hurco ncpp option
    By dannystooblue in forum HURCO
    Last Post: 04-09-2008, 03:50 AM
