Hi Guys
It has been a while since I have posted. Sorry for my absence.
With all the Fanfare for the Duality Lathe option I thought I would offer another option. For very little investment you can make a tool holder and use your mill as a vertical lathe with indexable tooling. I made my tool holder in a few hours. Well worth the time. Here is the long and short of it.
Work is held in the spindle , Tools in the tool holder.
Drawbacks
R8 spindle, anything over 1" needs a chucking lug.
no center support , short overall lengths.
no CAM support, you'll have to write the code yourself ( Or do some fancy editing )
Here is a picture of the Tool holder.
The toll holder is 2"x 2"x 11" Mild Steel
To make programing easier I used a different work offset for each tool. I bored the tool holder with three 3/4" bores so I could use my Tormach Tooling. The ER 20 collets will hold anything up to a 1/2". With a spot drill , a drill and a boring bar you could do just about anything. But I added an extra hole anyway. The Spot drill has a place all its own.
In the following Video I am making 4 collars for a product I sell. The material is 1018 mild steel 5/8" dia.
OP 1 Face and turn ( Chamfers are done here with the turning tool )
OP 2 Spot drill
OP 3 drill ( Deep hole 2.3" )
OP 4 ream to size ( reamed to 2.1" deep )
OP 5 Cut Off
LINK TO VIDEO
This is the only job I have used this for yet. But I did build in some room for expansion. With 2.5" between tools I can swing Nearly a 5" work piece.
I milled a small flat on the tool holder ( Weldon style ) and have a 3/8" Flat point set screw to clamp it down.
Food for thought guys .... Let me know what you think.
Scott
