586,385 active members*
3,476 visitors online*
Page 1 of 4 123
Results 1 to 20 of 69
    Apr 2007
    4
    Full cnc controller
    hello
    i have build a full cnc controller who can control full cnc machine without computer
    the board read the gcode in a sd-mmc card and drive the motors up to 50khz
    for the moment it do only linear interpolation (3axes) and drive the spindle with pwm and can switch on /off the coolant
    a manual mode can jog all axes in contius or in increments of 0.01 , 0.1 , 1 , 10 mm
    the remote mode is for rs232 com for sending one after one line of gcode
    the display is a simple KS0108 128*64 graphic lcd
    i have inclued a bootloader for flashing MCU without remove it
    when someone want to test i put the pcb on line and the firmware
    Attached Thumbnails Attached Thumbnails DSC00953.JPG   DSC00957.JPG   DSC00960.JPG   DSC00958.JPG
    Attached Files Attached Files
    Mar 2008
    3655
    Very interesting! Kudos!
    CR.
    Mar 2004
    222
    great job, I tried to do the very same thing, but was not able to complete it due to lack of knowledge .
    mhel
    "This is intentionally left blank."
    Mar 2006
    arnaud2 ,I want to test it,please put the pcb and schematic ,or email to me:[email protected],thanks.
    Apr 2007
    4
    here is the pcb
    i have not doing schematic but it's easy tu understand how it works
    you must at the first programming the pic18f4620 with bootload.hex and after put the program with the bootloader software
    it have some little bug but that are modified in the next time
    if you have question
    Apr 2005
    629
    Very impressive work!
    Chris
    Apr 2006
    169
    Apr 2008
    Nov 2005
    1468
    Respect!
    That is some neat engineering
    I love deadlines- I like the whooshing sound they make as they fly by.
    Sep 2006
    218
    yap, nice
    Can you post schematics?
    What I really like to see is the source code, or the algorithms used for interpreting G-codes
    I can share my own design, with pic+ ethernet...
    Apr 2007
    4
    i cant give all the source code but i can give some routines of the program must be 100% free and i dont want that someone make buisness with it
    it is integrally writen with mikrobasic (aproximative 2500 lines of code)
    90% is only the menu and the display
    for driving the motors it use a simple bresenham algorythm
    Code:
    sub procedure do_line
    if px>maxx then fail=1 end if
    if py>maxy then fail=2 end if
    if pz>maxz then fail=3 end if
    if px<0 then fail=1 end if
    if py<0 then fail=2 end if
    if pz<0 then fail=3 end if
    dx = ax - px
    dy = ay - py
    dz = az - pz
    dx = dx * stepratio
    dy = dy * stepratio
    dz = dz * stepratio
    stvel = 50000/(stvel1*stepratio)
    speed2 = 50000/(speed*stepratio)
    speed3 = 0
    acc2=acc
    coord = 0
    coord1 = 0
    coord2 = 0
    mx = 0
    my = 0
    mz = 0
    inv = -1
    ct = 0
       if dx < 0 then portb.6 = 1 dirx = 1  dx = dx*inv
                 else portb.6 = 0 dirx = 0  end if
       if dy < 0 then portb.4 = 1 diry = 1  dy = dy*inv
                 else portb.4 = 0 diry = 0  end if
       if dz < 0 then portb.2 = 1 dirz = 1  dz = dz*inv
                 else portb.2 = 0 dirz = 0  end if
       if dx > stepratio then spi_glcd_write_text("   MOVE",15,1,1) end if
       if dy > stepratio then spi_glcd_write_text("   MOVE",15,2,1) end if
       if dz > stepratio then spi_glcd_write_text("   MOVE",15,3,1) end if
       vm = sqrt((dx*dx)+(dy*dy)+(dz*dz))
       vm2 = vm
       if speed2 < stvel then speed3 = stvel  vel = 1
                              endvec = acc*((stvel-speed2)/10)
                         else speed3 = speed2  vel = 0
                              endvec = 0
                         end if
          while (vm>0)and(porta.4=1)and(fail=0)
          if (portd.1=1)and(portc.0=0)and(menu=1) then spi_glcd_write_text(" PAUSE ",76,6,1)
                                                  delay_ms (1000)
                                                  while (portd.1=0)and(portc.0=0) wend
                                                     end if
                                                  end if
          if vel=1
             then ct = ct +1
                  if ct = acc2 then speed3 = speed3-10 ct = 0 end if
                  if speed3stvel then speed3 = stvel end if
                  end if
          for delay = 0 to speed3
          nop
          next delay
          vm = vm - 1
          if dx<>0 then
          if coord > dx then coord = coord - vm2
                             portb.7 = 1
                             mx = mx +1 end if end if
          coord = coord + dx
          if dy<>0 then
          if coord1 > dy then coord1 = coord1 - vm2
                              portb.5 = 1
                              my = my + 1 end if end if
          coord1 = coord1 + dy
          if dz<>0 then
          if coord2 > dz then coord2 = coord2 - vm2
                              portb.3 = 1
                              mz = mz + 1 end if end if
          coord2 = coord2 + dz
          delay_us (2)
          portb.3 = 0
          portb.5 = 0
          portb.7 = 0
          wend
       if dirx = 1 then ax = ax + (mx/stepratio)
                   else ax = ax - (mx/stepratio)
                   end if
       if diry = 1 then ay = ay + (my/stepratio)
                   else ay = ay - (my/stepratio)
                   end if
       if dirz = 1 then az = az + (mz/stepratio)
                   else az = az - (mz/stepratio)
                   end if
    end sub
    if someone have a code to do circular interpolation with G02 and G03 i can integrate into the program
    for reading gcode it's verry simple i read it line after line
    if the 3 first carracters are G00 then rapid move
    if G01 the controled speed move
    here is the routine to read the values
    at the first i read a comlete line into the mmc (the routine is integred in mikrobasic) ans store it in a array of bytes
    Code:
    sub procedure read_gcode
    file = 0
    divider = 1
    while ((data[pointer]<47) or (data[pointer]>58)) and (pointer > 3)
          pointer = pointer - 1
          wend
    if (data[pointer]>47) and (data[pointer]< 58) and (pointer > 3)
       then file = (data[pointer]-48) * 100
       end if
    if (data[pointer]=46) and (pointer>3) then divider = 10
                                               pointer = pointer - 1 end if
       then file = file + (data[pointer]-48)*1000
            end if
    if (data[pointer]=46) and (pointer > 3) then divider = 100
       then file = file + (data[pointer]-48)*10000
            end if
       then file = file + (data[pointer]-48)*100000
            end if
       then file = file + (data[pointer]-48)*1000000
            end if
       then file = file + (data[pointer]-48)*10000000
            end if
    if (data[pointer]=45) and (pointer > 3)
       then inv2=1
       else inv2=-1
            end if
    file = file /divider
    if (data[pointer]=88) and (pointer > 3) then px = file+opx end if
    if (data[pointer]=89) and (pointer > 3) then py = file+opy end if
    if (data[pointer]=90) and (pointer > 3) then pz = (file*inv2)+opz end if
    if (data[pointer]=70) and (pointer > 3) then setspeed = file/10 end if
    if (data[pointer]=83) and (pointer > 3) then setrpm = file/100 end if
    if (data[pointer]=84) and (pointer > 3) then tool = file/100 end if
    file = 0
    end sub
    Jun 2004
    33
    seen ths
    http://www.fisertek.it/index_000044.html
    i was hoping to see it finished but the owner of the webpage email me saying he doesn't have time
    hopefully I can make Arnaud2's great cnc controller
    thank you so much for sharing
    Jul 2006
    16
    Very interesting project.
    I want to do the own project on a base ARM + ethernet ( EKI LM3S8962 ) + ELM -DC servomotor controller (New version ).
    Oct 2007
    57
    Quote Originally Posted by arnaud2 View Post
    [/code]
    Just a thought. For the rest of us that arn't as talented or don't have the time, it would great to be able to purchase a kit. I'm thinking like the linistepper drivers. One other thought, maybe in a later version add a usb port for thumb drives.
    Mar 2008
    5
    hi,
    plz.put the pcb and the firmware
    Feb 2005
    122
    firmware is the first post.
    I'm curious if someone has build it and how it works.
    @arnaud, any new versions ?
    Apr 2008
    57
    Jul 2006
    16
    I need the type of simple KS0108 128*64 graphic lcd for Full_CNC.
    Is it BG12864 or DG-12864 or WG12864 or ...?
    Help me !
    Jan 2007
    146
    Quote Originally Posted by vasyl markiv View Post
    Help me !
    From the author discussion on the french site:
    http://74.125.65.132/translate_c?hl=...NQUbizxQnJ_CQA
    http://74.125.65.132/translate_c?hl=...qe6Y8-FMBrtRvw
    Feb 2005
    122
    I think that they will work. Any display compatible or including ks0108 controller will be compatible. Unfortunately nobody can confirm that has build this controller.
Page 1 of 4 123
  1. need full CNC kit for ZX-45
    By ma1 in forum Benchtop Machines
    Last Post: 02-11-2012, 08:23 PM
  2. FULL CNC or DRO
    By Gunther45 in forum Benchtop Machines
    Last Post: 06-08-2008, 03:28 PM
