586,379 active members*
3,686 visitors online*
Page 2 of 4 1234
Results 21 to 40 of 69
  1. #21
    Apr 2008
    57
    L-am facut eu dar inca nu am legat la el driverele pentru motor sa vad cum se misca
  2. #22
    Jul 2006
    16
    My LCD BG12864E(Bolymin) now is working with new Arnaud CNC .
    Thank you!!
  3. #23
    Feb 2005
    122
    So, until now two persons have build this controller. Also it seems that displays like 12864 are working.
    Vasyl - did you connected it to a machine ? Did you succeed to run a G-code ?
    Keep us informed - maybe some pictures ?
    Daniel
  4. #24
    Jul 2006
    16
    The New Arnaud CNC from (http://www.usinages.com/controleur-a...-t2415-75.html ) is working with UHU servo controller . With the help of Arnaud I was run G-code file :
    G00 X100 Y10 Z5
    G01 Y20 F13
    M03 S2000
    G01 Z20
    G00 X0 Y0 Z0
    G01 X10 F21
    G01 Y10 F22
    G01 Z0 F23
    G01 X123 Y321 Z0 F24
    M05
    M02
    But non-uniformity of movement is observed. Impulses on the controller go packages with a pause. I yet have not tested the command G02 and G03 .
    Vasyl Markiv
  5. #25
    Jul 2006
    16
    Photo of Arnaud CNC
    Photo of Arnaud CNC with UHU servo .
  6. #26
    Feb 2005
    122
    Thanks for update and pictures Vasyl.
    I am planning to build myself Arnaud controller.
    From your pictures I see that you had the same problem that I have found : my display doesn't have the same pinout like that one of Arnaud.
    TEsting with a stepper motor would spot maybe better if it is a controller or driver problem.
    What was the problem when you needed Arnaud's help ?
  7. #27
    Jul 2006
    16
    Arnaud CNC
    In cnc.zip there are files of printboard in *.pdf , *.gif and SprintLayout format and gcodetxt . In arnaud.zip is an example of Proteus file for emulation ArnaudCNC . With a stepper motor you will feel a pause between packages of impulses . I think .
    Arnaud's projects and are very well made and thought over, they are easy for understanding . Arnaud was help me with a LCD , format of Gcode file , and ...!!!
    Best regards
    Vasyl Markiv
    Attached Files Attached Files
  8. #28
    Oct 2006
    32
    Arnaud
    What version of Proteus you used? (7.2 or 7.3)
    Regards!
    S.M.
  9. #29
    Jul 2006
    16
    Proteus 7.4 SP3
  10. #30
    Oct 2006
    32
    Arnaud
    Vasyl, thanks!
    I am tested on Proteus 7.4 and it's ok. Next mont I will made board for test on cnc-mill. After that I will post here and Usinages about that.
    S.M.
  11. #31
    Jun 2007
    7
    Quote Originally Posted by Markovic Slavol View Post
    Vasyl, thanks!
    S.M.
    is there any news about ?
    good luck
  12. #32
    Mar 2006
    Smile
    Quote Originally Posted by vasyl markiv View Post
    Best regards
    Vasyl Markiv
    In this Circuit, Crystal is 10MHz or 40MHz? How config cpu's fuse?
  13. #33
    Jul 2006
    16
    Crystal is 40 Mhz , fuses in *.hex file .
  14. #34
    6
    arnaud2 Nice work and thanks for sharing some of the information with us.
    Regards
    Bart
  15. #35
    Jul 2009
    The New Arnaud CNC from ([url]
    Vasyl Markiv
    hello world
    I too have built
    but the movements are only those running with the keys
    mmc card with makes all movements at random layers
    and non-uniform
    however I have seen on youtube who made the new version and it seems that works
    http://www.youtube.com/user/arnaud9173
    http://www.youtube.com/watch?v=HLuTF0bYsy0&eurl=http%3A%2F%2Fwww%2Eyoutube%2Ecom%2Fuser%2Farn aud9173&feature=player_profilepage
    ARNAUD what have you done?
    where are you?
    the end the project or you have left?
    however, thanks to the work you have done until now
    PS:
    sorry my English
    but ITALIAN
  16. #36
    Dec 2008
    51
    could you give code for g02 and g03
    thanks
  17. #37
    Feb 2009
    Congratulations arnaud2, can you help me?
    Great job!!!!! and thank you for all arnaud2, but please, help me -> describe routines for aceleration, setup velocity, acelereation and pulses . I don't understand that. I like theory for this or references.
    Thank you very much,
    greetings
  18. #38
    Jan 2010
    Hello! The help is necessary to me. A problem with the display. How it can be corrected? Thanks.
    http://www.usinages.com//files/gluuk_182.jpg
  19. #39
    Jul 2009
    hello
    must reverse the CS1 with CS2
    the dispay
  20. #40
    Jan 2010
    Thanks!!!
    And who knows something that the author? he threw the project? or discussion shifted to another place?
Page 2 of 4 1234
  1. need full CNC kit for ZX-45
    By ma1 in forum Benchtop Machines
    Last Post: 02-11-2012, 08:23 PM
  2. FULL CNC or DRO
    By Gunther45 in forum Benchtop Machines
    Last Post: 06-08-2008, 03:28 PM
