586,762 active members*
8,461 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Continue subprogram after push "CYCLE-STOP"
    Jun 2008
    Question Continue subprogram after push "CYCLE-STOP"
    If i'm press CYCLE-STOP button example in line number N6000, after this I'm dont continue program from line N6001. If I'm press CYCLE-START - program always started from first line.
    My main program:
    M198 P0003;
    M30;
    My sub-program on Data Server HDD:
    O0003
    N6000 ... <------------ in this line i'm press CYCLE-STOP
    N6001 ...
    N7000 M99;
    I'm try to insert "GOTO 6001" in third line of sub-program, but raised error 123 - "CAN NOT USE MACRO COMMAND IN DNC ". What i'm do wrong?
    Also, cant put cursor on line N6000, after push "CYCLE-STOP" - subprogram instantly interrupted and returned to main program.
    Or exist another way to continue my subprogram from line, where program interrupted, or CNC is sudden power off?
    Jun 2008
    isn't nobody don't know it?
    Or all users of FANUC 18i,21i, ... be tormented as me?
    Aug 2006
    98
    It´s not possible run an custom macro from DNC function. I do this test yesterday. Try use relocate program using type P or type Q, but don´t use M198 to call the program.
    Daniel
  1. G320 "common" or "+5vdc" why do they vary?
    By beezerlm in forum Gecko Drives
    Last Post: 01-12-2008, 11:00 PM
  2. Has anyone looked at the "JET" or "Shop Fox" manual machines?
    By boosted in forum Uncategorised MetalWorking Machines
    Last Post: 03-05-2007, 04:33 AM
  3. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
  4. Mach2 bombs when I hit the "stop" button
    By Stuff-Builder in forum Mach Software (ArtSoft software)
    Last Post: 09-28-2005, 04:09 PM
