586,980 active members*
4,096 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal quick code sheet from years back
Results 1 to 3 of 3
    Jan 2007
    1389
    Years ago (1990) Fadal Came out with these little quick code cards. we always kept them by the machine for reference. I couldnt find mine for about 3 years and then low and behold I found 4 of them, they are on a 5x 6 laminated card front and back.
    I will try to scan a copy of the front and back of the org.
    Thought since I had some time to type them up, I would post them. just copy and paste them then print and laminate, keep them next to your machines.
    Front Left Colum
    • G00 POINT TO POINT POSITIONING
    • G01 LINEAR INTERPOLATION
    • G02 CIRCULAR INTERPOLATION
      (ARC CLOCKWISE)
    • G03 CIRCULAR INTERPOLATION
      (ARC COUNTER CLOCKWISE)
    • G04 DWELL (P-WORD MILLIESECONDS)
    • G05 NON-MODAL RAPID
    • G08 ACCELERATION (NO RAMPS)
    • G09 DECELERATION (RAMPS)
    • G10 PROGRAMMING DATA INPUT
      (L02=FIXTURE X,Y,Z P=#,
      L10=LENGTH,P=#, R0=AMT,
      L12=DIAMETER,P=#,R0=AMOUNT,
      L100-L109=R VALUES,P=AMT)
    • G15 YZ CIRULAR INTERPOLATION
      (WITH A AXIS)
    • G16 XY CIRULAR INTERPOLATION
      (WITH C AXIS)
    • G17 XY PLANE
      (Q WORD FOR A AXIS MAPPING)
    • G18 ZX PLANE
    • G19 YZ PLANE
    • G20 INCH PROGRAMMING
    • G21 METRIC PROGRAMMING
    • G28 RETURN TO ZERO
    • G29 RETURN FROM ZERO
    • G40 CUTTER COMPENSATION CANCEL
    • G41 CUTTER COMPENSATION LEFT
    • G42 CUTTER COMPENSATION RIGHT
    • G43 TOOL LENGTH COMPENSATION POS.
    • G44 TOOL LENGTH COMPENSATION NEG.
    • G45 TOOL OFFSET SINGLE EXPANSION
    • G46 TOOL OFFSET SINGLE REDUCTION
    • G47 TOOL OFFSET DOUBLE EXPANSION
    • G48 TOOL OFFSET DOUBLE REDUCTION
    • G49 TOOL LENGTH OFFSET CANCEL
    • G50 RAMP SLOPE CONTROL CANCEL
    • G50.1 MIRROR IMAGE CANCEL
    • G51 RAMP SLOPE CONTROL
      (R0=RAMP SPEED VALUESOF .5-2.
      +SIGN=Z AXIS, -SIGN=XY AXIS)
    • G51.1 MIRROR IMAGE
    • G52 LOCAL COORDINATE SYSTEM
    • G53 MACHINE COORDINATE SYSTEM
    • G54-59 FIXTURE OFFSETS
    Front right colum
    • G66 MODAL SUBROUTINE CALL
      (L=SUBROUTINE)
    • G67 MODAL SUBOUTINE CANCEL
    • G68 ROTATION(R0=ANGLE
      X,Y=CENTER OF ROTATION)
    • G69 ROTATION CANCEL
    • G70 INCH PROGRAMMING
    • G71 METRIC PROGRAMMING
    • G73 PECK DRILL (Q= STEPSIZE
      I= INITIAL PECK J=REDUCING VALUE
      K=MINIMUM PECK)
    • G74 LEFT HAND TAP
      FORMAT 1 (Q=THREAD LEAD, F=RPM)
      FORMAT 2 (F=FEEDRATE, NO Q)
    • G75 TAPPING HEAD CYCLE
    • G76 FINE BORING
      (Q=AMOUNT OF Y+ SHIFT OR
      I=AMOUNT OF X SHIFT, J=AMOUNT
      OF Y SHIFT
    • G80 FIXED CYCLE CANCEL
    • G81 DRILL, SPOT DRILL
    • G82 DRILL, COUNTERBORE
      (P=MILLISECONDS)
    • G83 DEEP HOLE CYCLE (Q=STEPSIZE
      I=INITIAL PECK, J=REDUCING VALUE
      K=MINIMUM PECK
    • G84 RIGHT HAND TAP
    • G85 BORE IN/OUT
    • G86 BORE IN/SPINDLE OFF/RAPID OUT
    • G87 BORE IN.OUT
    • G88 BORE IN/DWELL/OUT
      (P=MILLISECONDS)
    • G89 BORE IN/DWELL/OUT
      (P=MILLISECONDS)
    • G90 ABSOLUTE POSITIONING
    • G91 INCREMENTAL POSITIONING
    • G91.1 HIGH SPEED EXCECUTION
    • G91.2 HIGH SPEED EXCECUTION CANCLE
    • G92 ABSOLUTE PRESET
    • G93 1/T FEEDRATE SPECIFICATION
    • G94 FEEDRATE SPECIFICATION DPM,IPM
    • G98 RETURN TO INITIAL PLANE
    • G99 RETURN TO R0 CLEARANCE PLANE
    BACK SIDE
    • L9201 ENGRAVING (R1+0=STD R1+1=STEN R1+2=SERIAL STD R1+3=SERIAL STEN,
      R2=HEIGHT, R3= ANGLE, R4=SERIAL INCREMENT 1-9,
      R0=CLEARANCE PLANE, Z=FINAL DEPTH, F=FEED RATE)
    • L93NN BOLT CIRCLE R0=I, R1=J, R2=ANGULAR STEP, NN=AMOUNT OF HOLES)
    • L94NN MILL BORING CYCLE CCW (R0=FEED, R1=DIA. OF HOLES, NN=REPETITIONS)
    • L95NN MILL BORING CYCLE CW (R0=FEED, R1=DIA. OF HOLES, NN=REPETITIONS)
    • L9601 RECTANGULAR POCKET CCW (R0=FEED, R1=RAD. ON TOOL ,R2=X, R3=Y)
    • L9701 RECTANGULAR POCKET CW (R0=FEED, R1=RAD. ON TOOL ,R2=X, R3=Y)
    • L9801 CIRCULAR POCKET CCW (R0=FEED, R1=RAD. ON TOOL ,R2=DIA. OF HOLE)
    • L9901 CIRCULAR POCKET CW (R0=FEED, R1=RAD. ON TOOL ,R2=DIA. OF HOLE)
    NOTE: INPUT OF THE R PARAMETER REQUIERS THE SIGN (+ OR -)
    • M00 PROGRAM STOP
    • M01 OPTIONAL START
    • M02 END OF PROGRAM (FORMAT 1)
    • M03 SPINDLE ON CLOCKWISE
    • M04 SPINDLE ON COUNTERCLOCKWISE
    • M05 SPINDLE OFF
    • M06 TOOL CHANGE
    • M07 COOLANT ON FUNCTION
    • M08 COOLANT ON FUNCTION
    • M09 COOLANT OFF FUNCTION
    • M10 CANCEL RECIPROCATION
    • M11 X AXIS RECIPROCATION
    • M12 Y AXIS RECIPROCATION
    • M13 Z AXIS RECIPROCATION
    • M14 B AXIS RECIPROCATION
    • M15 A AXIS RECIPROCATION
    • M17 END OF SUBROUTINE
    • M18 CYCLE CUSHMAN INDEXER
    • M19 SPINDLE STOP/ORIENT
    • M20 CYCLE INDEXER
    • M30 END OF ALL SUBROUTINES
      END OF PROGRAM(FORMAT 2)
    • M41 LOW RANGE RPM
    • M42 HIGH RANGE RPM
    • M45 EXECUTE FIXED CYCLE
    • M46 SET POSITIVE APPROACH
    • M47 CANCEL POSITIVE APPROACH
    • M48 FEEDRATE AND RPM POT-IN
    • M49 FEEDRATE AND RPM POT-OUT
    • M60-69 USER ATTACHED DEVICES
    • M96 CANCEL INTERSECTIONAL CRC
    • M97 INTERSECTIONAL CRC
    • M98 EXECUTE SUB PROGRAM
      (P=PROGRAM #, L=REPETITIONS)
    • M99 END OF SUB PROGRAM
    Please double check these as my typing and eye sight sucks, I did go through them a few times to verify.
    Apr 2007
    64
    Here's a link to the newer version.
    http://www.compumachine.com/Support/...gram_Codes.pdf
    Jan 2007
    1389
    well damn if I would have known that it would have saved me lots of typing, Thanks for the heads up.
  1. G Code Cheat Sheet?
    By cp8071 in forum G-Code Programing
    Last Post: 08-20-2014, 10:07 PM
  2. A few concerns about Quick Code.
    By l u k e in forum Haas Visual Quick Code
    Last Post: 04-17-2009, 01:34 PM
  3. Visual Quick Code on TL4
    By speeeeed in forum Haas Lathes
    Last Post: 01-14-2008, 09:49 PM
  4. Quick Code, Visual Quick Code
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-17-2006, 04:46 PM
  5. Fadal is back on top!!! NOW WITH PICS!!
    By carbidecraters in forum Fadal
    Last Post: 04-08-2006, 02:52 AM
