586,776 active members*
8,975 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA LB15 "ALARM 206 A Shear Pin 4"
Results 1 to 8 of 8
    May 2008
    10
    Hello all people,
    I have purchased a Old Okuma LB 15 twin turret turning machine.
    When I have powered on theis machine, There is alarm appeared on screen " ALARM 206 A Shear pin 4"
    I have checked the alram list in the machine manuls, but there is no 200 series alarms in those manuls.
    Does any body know what type of alarm is this? and how can i get rid of that?
    Please help me.
    regards.
    Risna
    Sep 2007
    44
    error msg
    Our book says "The shear pin between the brushless motor and the ball screw is broken." Probably on the XA. The book says replace the pin.
    Jan 2008
    136
    yes it could be the shear pin, but it may also be a bad shear pin monitoring switch.
    Jun 2008
    Shear pin
    The shear pin holds the 2 pullys by the x axis motor you need to see if its broken you will need a special nut to get the taper lock off if needed look in the parts book it will show u the shear pin,
    May 2008
    10
    An other alarm
    Thanks all,
    I have got those shear pins. yes pins were broken.
    l have replaced those pins and the alarm was gone.
    But now machine is moving its all axes only in "MANUAL" mode. When I have pressed any other mode button, there is an Alarm" 124 Storke end limit cancel" appeared on screen.
    The operating and Maintenance manual says "Operation other than Manual is selected while the storke end limit cancel switch is ON"
    Where is the loction of this switch?
    Please help me
    Regards.
    Risna
    Sep 2006
    24
    Usually inside the electrical panel.
    Jun 2008
    Depending on the control its in the back in the elec cabinet a toggell switch that says o/t realese
    May 2008
    10
    Thank you
    Thanks all, you are the great People.
    And also the CNCZONE by which I will remain intuch with you.
    Yes I got that switch in the electric panel at back side of machine.
    I can not explain in words that how much you all are helpful to me.
    This machine was not in working from last two months. Now it is in working.Oh!!!!!! thanks God.
    Thanks and Regards.
    Risna
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Replies: 14
    Last Post: 01-08-2007, 06:10 AM
  3. Macro alarm "009 ILLEGAL ADDRESS INPUT"
    By theemudracer in forum Fanuc
    Last Post: 12-26-2006, 04:57 PM
  4. alarm "2013 AITL OFF" Hamai/FS-6M
    By Nat in forum DNC Problems and Solutions
    Last Post: 07-03-2006, 01:55 AM
  5. ALARM!!! "Commanded X Axis move too far / Positive"
    By aimeahz in forum Bridgeport / Hardinge Mills
    Last Post: 04-20-2006, 11:51 PM
