586,852 active members*
2,244 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > G65 and G74 in PartMaker SwissCAM
Results 1 to 3 of 3
    Feb 2009
    3
    Hey everyone! I have a couple questions that I would like to bounce off of everyone.
    Has anyone used a G65 in PartMaker to post a drill cycle rather than a G83? Or at least adjust the retract per peck? We have run into an issue were the G83 has had a large effect on our cycle due to the full retract on some deeper holes. Any thought on this?
    Also, does anyone know of a way to use G74/G75 in PartMaker? We have a part with a longe contoured bore and its creating a huge string of chips. Rather than breaking the bore into segmented profiles I would like to use a G74 if possible. Has anyone else run across this? What did you do to solve it?
    Any thoughts, ideas or suggestions are greatly appreciated
    Thanks!
    PACMan
    Dec 2008
    54
    G65, G74
    Hi Pacman,
    Some of our Posts are configured to use these commands. Check your addendum and User Data Pages to see if they are there. If not, you can always request these additions through [email protected]
    Jun 2008
    20
    G65 Drill Sub-program
    We use G65 on our Star SV Lathes. It looks like this (in Z):
    G65P8999A.06B.035C.02R0S-.02Z1.086W.02F.0012D1.5E4.0;
    We have this in our posts to output the G65 code with all the right info(thanks Bill C.) when ever we use deep hole drilling.
    Attached is the O8999 sub-program(drill macro.txt) and an explanation of how to use it(drill macro example.txt).
    There is a parameter in some controls that allow you to change the retract amount to come out of the hole or not. On the Stars it's parameter No. 5101-bit 2. Check your manual or use this sub-program.
    As far as G74/G75, never used it. Partmaker is pretty good at setting depth of cut (say .010")for a contour. Make sure your initial stock is set correctly (say .100")(10 rough cuts @ .010" - finish).
    drill macro.txt
  1. PARTMAKER USERS
    By SWISS-TECH in forum Uncategorised CAM Discussion
    Last Post: 09-05-2021, 03:21 PM
  2. Partmaker
    By DLMACHINE in forum Uncategorised CAM Discussion
    Last Post: 07-12-2019, 02:30 PM
  3. Anyone uses/used PartMaker software
    By WOLOG in forum Uncategorised CAM Discussion
    Last Post: 09-24-2010, 08:23 PM
  4. Experienced Partmaker guru?
    By hollisnhRob in forum Community Club House
    Last Post: 12-03-2008, 02:40 PM
