587,051 active members*
3,887 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Possible replacement motor for an X3?
Results 1 to 7 of 7
    Nov 2005
    655
    I was browsing Harbor Freight web site and came across what appears to be an X3 made for Central machines. It has less travel on the X and Z axis, but everything else looks identical to the other X3's.
    http://www.harborfreight.com/cpi/cta...emnumber=93885
    OHH! the other difference I found was it comes with a 1 hp motor instead of the 3/4 hp motor that came on mine.
    If I ever need to replace mine, it might make a good replacement motor (more power, more torque).
    Can you just order a motor from HF?
    Later,
    Jack
    Walking is highly over-rated
    Mar 2008
    220
    Try the 800 number
    They may be able to, but I have a feeling you won't be able to. They don't sell just the parts from when I spoke to them before I bought mine. If they didn't have what I was looking for, well, I just couldn't get it. I asked for something which I can't remember what it was at the moment, but there you go.
    Mar 2008
    3655
    Quote Originally Posted by tauntdesigns View Post
    OHH! the other difference I found was it comes with a 1 hp motor instead of the 3/4 hp motor that came on mine.Jack
    I'm sure that is only sales hype--The way the X2 is touted with a 4/5 or 3/4 HP motor. It's probably the standard X3 600 watt motor. That MAY even be the standard X3, only with the early model specs.
    CR.
    Dec 2004
    38
    both motors are same - just rated differently by Grizz and HF.
    You can easily add your own motor if you feel the stock pwr is not enough.
    But, you will then hit limits of rigidity etc.
    Nov 2005
    655
    Bummer,
    I was hoping it would be an easy upgrade, a little more power and torque would've been nice.
    Oh well,
    Jack
    Jan 2006
    461
    Upgrading the motor is pretty darn simple and can be done for less than 100 dollars with a treadmill motor and a 1hp dc motor control.
    Nov 2005
    655
    That's what I'm doing for my lathe as soon as I figure a good way of mounting it.
    I was thinking..... for a little bigger motor without having a mounting problem.
  1. Replacement Motor - Supermax VNM
    By drb_001 in forum Uncategorised MetalWorking Machines
    Last Post: 07-18-2007, 05:21 AM
  2. Eldorado Motor Replacement
    By giantcake in forum Shopmaster/Shoptask
    Last Post: 05-30-2007, 12:24 AM
  3. Fanuc AC Motor replacement
    By asuratman in forum Fanuc
    Last Post: 09-22-2006, 01:32 PM
  4. Spindle Motor replacement?
    By Trapper14 in forum Mini Lathe
    Last Post: 03-10-2006, 11:48 PM
  5. Need stepper motor replacement help
    By ProjectCNC in forum CNC Machine Related Electronics
    Last Post: 01-29-2004, 10:14 PM
