586,655 active members*
3,571 visitors online*
Results 1 to 16 of 16
    May 2006
    7
    Cheap Small Lathe
    I am currently collecting bits and pieces to build a medium-sized steel/ali CNC router and I was considering buying a cheap, small lathe so that I could fabricate some of the parts I will need. I have wanted a lathe for some time now and this is the perfect excuse. Any thoughts on H & F's AL-30? or is there some thing better for <$800. Second hand would be OK but they are few and far between here.
    Jun 2004
    6618
    I guess those are Aussie bucks, so looks okay. I have the same machine basically and I like it alot. I have it cnc'ed now and it's even better. At this point, I wasn't going to put any more money into it, because it preforms well enough, however I will change the screws on the cross slide to a zero backlash acme rod. In manual mod though, backlash is easy to account for.
    Mine came from Cummins. It's actally my second. The first was from Northern Tool and my FIL had to have it.
    Lee
    May 2006
    7
    Thanks Lee, yes they are Aussie bucks A$729 = US$687
    Aug 2005
    52
    FYI that's a rebadged Sieg C2 lathe. I have a Hafco AL60M which is really a Sieg C6 with milling head (which is the column and spindle from a Sieg X2 mill).
    You might be able to find someone with a cheaper price for the C2 (or you could even import one direct from China) but HAFCO have been selling Sieg for a while and they probably make sure everything is electrically and mechanically sound before shipping the lathe to you.
    There are smaller lathes from Sieg - the C1 and C0 but the C2 is a good size. The C0 is way too small unless you're making scale model parts - I just CNC'd a C0... to make scale model parts.
    May 2006
    7
    Thanks jallitt. I ended up buying a H&F AL50GB lathe. All seems to be OK. It is the same as the Grizzly 9x20 lathe (as well as all the other Chinese clones).
    Apr 2012
    16
    Hi all,
    Thinking about an AL-60m lathe milling combo and was wondering about your thoughts as a first lathe/mill.
    Apr 2012
    16
    Just found another milling/lathe combo that looks better and cheaper than the AL-60M.
    It is an AL-280P Lathe Mill Drill Combo.
    The link is Machineryhouse L159 if link doesn't work.
    L159 | AL-280P Lathe Mill Drill Combination | machineryhouse.com.au
    Jun 2010
    4256
    YGWYPF
    Quote Originally Posted by Gregted View Post
    Just found another milling/lathe combo that looks better and cheaper than the AL-60M.The link is Machineryhouse L159 if link doesn't work.
    Those who buy cheap from the hares get cheap.
    You Get What You Pay For.
    OK for light hobbies I guess.
    Cheers
    Apr 2012
    16
    Quote Originally Posted by RCaffin View Post
    Cheers
    Yeah, It would be good to be able to afford a $10,000 lathe but no rich rellys or lotto wins yet. Unless you want to contribute to my funds and start me off on the right foot I will have to settle for something in this price range.
    There is no doubt truth in the saying get the biggest you can afford and this will be it for now. I think it is limited in some areas but having never owned a lathe, I hope it will be a good introduction to what a lathe can do.
    BTW thanks for your input. Constructive criticism is always appreciated.
    Greg
    May 2006
    7
    Hi Greg, It's been a while since I first posted this thread and since then I've upgraded from the H&F AL50GB lathe to a larger and more sturdy 300mm x 900mm S/H lathe.
    Regarding buying a lathe/mill combo, I thought about going down that path too but decided against it because it would require pulling setups to pieces evey time you wanted to switch between the lathe and the mill. Also, 2-in-1 machines are inevitable a compromise. I'd recommend that you steer clear of 2-in1 machines, you would be better off saving a bit more and getting a small mill and a lathe.
    Alternatives to what you may have looked at include:
    Lathe (generic 9 x20 lathe)
    My AL50 required a fair bit of work out of the box to achieve adequate rigidity... see my thread here on this lathe.
    H&F have them as do many other suppliers in Oz.
    Mini Mill, anyone of the X2 minimill clones is a good starting point for light milling work. Sold by H&F, Titan and Ozmestore.
    Good luck with the purchase!
    P.S. also check out this thead, more food for thought.
    Apr 2012
    16
    Thanks Steve,
    I checked out those threads and they made for some informative reading.
    I don't really need a mill, but was looking at the AL 60 anyway and thought as I was buying my first lathe, I might as well get one with the added option of a mill/drill.
    When you said that i will have to disassemble the combo to lathe or mill does that mean that the mill doesn't stay assembled through all operations?
    The AL60 is $1290 and the mill head is a further $560 so I don't need to buy the mill head straight up but in your opinion is this still not a good lathe to learn on?
    I was under the impression that a larger lathe just has a longer bed, larger distance from the headstock to the bed, and maybe a more powerful motor but there is obviously more to it than that.
    Thanks for your input sofar.
    Greg
    May 2006
    7
    Hi Greg, the bare AL-60 is $1290 + GST = $1419.
    Regarding tearing down setups, my understanding is that with combo machines, the work is fastened to the lathe carriage when using the mill, and therefore when switching from the mill to lathe, the setup on the carriage must be taken down in order to use the carrriage for the lathe tools. I'm no expert but others could provide their advice on this one. The mill attachment from the AL-60 looks to have the same head as the X2.
    Regarding whether the AL-60 will meet your needs, it depends on what you intend to do with it (size of the work and the required rigidity/accuracy). The more expensive and larger lathes generally tend to have improved rigidity that improves accuracy, all other things equal. The larger machines can also produce larger work and tend to be more powerful. However, the smaller machines tend to spin a bit faster and maybe more suitable for smaller work.
    In the end, either lathe will probably be OK to start off with and you can always sell it if you decide to upgrade later on. I sold my AL50 for a VERY good price 3 years after I bought it (it was in good nick and well maintained) so there appears to be a good demand for used small lathes in good condition.
    Dec 2007
    362
    I have an AL-60 (actually a Sieg C6 from Carbatec) and I'm happy with it's performance.
    I would avoid the combo version as the will head will get in the way and the when used as a mill, the lathe parts will get in the way.
    Buy the X2 mill as standalone, should cost you less than $900.
    If I was buying a mill now, I'd look at this one from Titan Machinery. It's pretty much the same as the G0704 from Grizzly.
    Regards
    Geoff
    Apr 2012
    16
    Quote Originally Posted by tumutbound View Post
    Thanks Geof,
    I have been in this situation many times before. Bought something and a month or year later wished I'd bought a bigger one but having struggled through 30 odd years of making do with a drill press and vise to machine what I wanted, I think as an entry into what a lathe can do, I will be happy with this choice.
    I don't really have a use for a mill, but was looking at the C6 anyway before I saw the combo option.
    I think I will take the advice of yourself and others and just go with the lathe on it's own.
    I can always add the mill later if I decide to do so..
    I would be interested in pictures or stories of what you have used your lathe for. It may give me some ideas of what I can achieve on mine. I don't have anything immediate to use it for but have always wanted one.
    Greg
    Feb 2012
    You're choosing a mini lathe is there a reason for the small lathe? ie space.
    I have a mini lathe but spce was a restriction and if I had space then I would have bought a larger lathe simply because the mini lathe is restricted to what it can do in terms of job size and is a bugger to part off but this can be overcome with turning the tool upside down in the toolholder and reversing the motor/chuck direction,also spindle bore is only 20mm that means you cannot turn long stock bigger than that 20mm.
    I bought my lathe second hand off ebay as I did not want to pay new pricing,the machine is fine but I had to do some modifications as it was still factory standard.
    Feb 2012
    Eh! I thought those combination lathe/mill was that you could swing the mill's turret out of the way when not using the mill?
    If you look at the AL-280P it swings 90 degrees either way it has to just in case the job in the lathe needs offset drilling/milling.
  1. Replies: 15
    Last Post: 05-05-2011, 11:59 PM
  2. Dirt Cheap small mill
    By KrashKing405 in forum DIY CNC Router Table Machines
    Last Post: 11-16-2008, 05:00 PM
  3. Small Cheap flood Coolant system
    By dneisler in forum Benchtop Machines
    Last Post: 05-11-2007, 03:48 PM
  4. Cheap, small, stepper Pic Driver II
    By Ragnarok in forum Stepper Motors / Drives
    Last Post: 07-02-2006, 03:40 AM
  5. Cheap, small, stepper Pic Driver - Developing
    Last Post: 06-02-2006, 08:39 PM
