586,504 active members*
3,343 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > CNC Fusion X2 Ballscrews, Y screw is too long.
Results 1 to 9 of 9
    Apr 2008
    46
    Just fyi in case anyone runs into why they can't mount their Y screw.
    My Ballscrew came over a little 1/4 inch too long and was hitting the X2 Mill base, after a quick grind, all was well.
    Also CNC Fusion should ship Spanners for the spanner nut, as I ended up using large tools to get that nut on. But ended with teeth groves on the end of the shaft where I had to grind out smooth before I was able to attached the Heli-Cal coupling. From other threads I've read, CNC Fusion know about this, but I don't know why they don't fix it. I can't image it being an expensive tool. I would have paid the difference to have it in the kit.
    Dec 2006
    14
    My kit I just got from them fit my X2 perfect. Although I've seen HF mill bases have large amounts of flash on them. I had to grind mine back because nothing fit it really. Including the stock screw would bind occasionally. Their kits was top quality on my install.
    Mar 2008
    3655
    Quote Originally Posted by spaceballs_3000 View Post
    I hope you didn't grind that 1/4" off of the BALLSCREW! If you did that, then you cut down the already miniscule X2 Y travel by 1/2 inch. Better to grind the base to make room for the ball screw end.
    Also, you may need to install some kind of "hard stop" to prevent the Y ballscrew from coming out of the ball nut and spilling bearings all over the floor.
    CR.
    Jun 2004
    822
    I had the same problem with Hoss' CNC conversion. The Y screw was too long according to his drawings. I just ground out a pocket in the base for the screw to fit. I think there is just a lot of variance in the 'flashing' of these as TheWolf stated.
    Apr 2008
    46
    Quote Originally Posted by Crevice Reamer View Post
    CR.
    Yeah I didn't think about that until after I did it
    Oh well...
    no need for hard stop, it hits the base and stops on it's own.
    Mar 2008
    3655
    ...no need for hard stop, it hits the base and stops on it's own.
    Yeah, you're right! Been a while since I was inside the X2. I was thinking of the X3.
    CR.
    Jul 2013
    I'm having the same issue with the Y screw being too long right now. I think I will be making a pocket in the base to make room for the screw. I have the LMS mill with solid column and I bought kit #5 from CNC fusion. I think the solid column mill may have a little bit beefier base that is causing the problems.
    ~Adam
    May 2005
    3920
    Quote Originally Posted by mrcodewiz View Post
    Could be flashing but it also could be variance from one pattern to another. Considering the mass production status I would imagine that they have at least a couple of patterns around. This doesn't even get into machining allowance in the castings and the actual machining done.
    Jun 2004
    16
    I had the same issue with my X2/Large Table CNC Conversion project. The large base is a lot beefier than the X2 base. I cut a pocket in the large base and gave the ball screw plenty of room. Fortunately I was able to do it on the X2 as I converted the large table to CNC then mounted it to the column when it was working.
  1. Syil X3 CNC or X3 + CNC Fusion + etc
    By iamscottym in forum Benchtop Machines
    Last Post: 05-11-2008, 11:43 AM
  2. CNC Fusion Kits
    By Regnar in forum Benchtop Machines
    Last Post: 04-06-2008, 11:00 PM
  3. CNC Fusion kit questions
    By Hellbringer in forum Benchtop Machines
    Last Post: 02-05-2008, 07:17 PM
  4. CNC Fusion
    By Memran in forum Benchtop Machines
    Last Post: 04-04-2007, 12:20 AM
  5. CNC Fusion kits
    By Redline in forum Benchtop Machines
    Last Post: 11-02-2006, 01:22 AM
