Nobody? Here's a stab at a couple of the questions
Originally Posted by
highwaymancnc
I would like to able to just do this by jogging to the material height and then setting it. Is this possible?
That's why we have touch-off. No different than setting x or y. Unless you have a way of setting predictable tool lengths. In that case check into the use of G43.
2nd, my table size is 12 X 24 X 6 but for most of the work I think that this won't be used much at this expanse. Should I create several INI setup files for various job sizes
No reason I can think of.
MAX_LIMIT MIN_LIMIT units in the INI file are what exactly. Are they in inches if I use Inch INI and millimeters if I'm using mm INI
yes
why do I see minus values in the INI files...... could you explain this as well.
My guess is the same as your's. Someone will likely come along with a clear explanation.
