586,275 active members*
3,152 visitors online*
    Apr 2005
    30
    Worm gear and worm drive
    I've attached two dxf files that show a worm gear and a worm drive. I'm looking for quantity two of each for now. This is a new product that I am working on and if it pans out there would be requests for more. I will take suggestions on material. I've spec'd. 1018 for the worm drive and gear bronze for the worm gear.
    Private email me at "[email protected]" with quotes / questions.
    There is no rush at this time as I am very busy with other projects. I'd like to see all quotes to me by 5/2/08.
    P.S. had to zip the worm gear dxf file as it was too big to upload.
    Attached Files Attached Files
    Mar 2006
    2712
    LEWENZ, I think you'll want a steel that can be hardened better than 1018. Also, you'll need a fine finish on the worm to avoid "eating" the worm gear.
    Have you investigated Boston Gear or Martin Sprocket/Gear for an available set? Or better yet, Cone drive for full enveloping worm/worm gear sets?
    Just a thought.
    Dick Z
    DZASTR
    Apr 2005
    30
    Gears
    Thanks, Richard.
    I will be looking at a few other sources.
    Mar 2006
    2712
    LEWENZ, I looked up www.bostongear.com open gear catalog. There's a good engineering section that includes worm gearing info. I also copied your prints. The dimensions don't appear standard stuff. Just for jollies, look at 24 DP 72 teeth.
    I believe you're working on some rotary devices. If so, are your requirements for a given ratio, center distance or ?
    Maybe I can help.
    BTW, I live near Milwaukee. (your "about me" says you do as well ).
    Dick Z
    DZASTR
  1. Zero backlash worm gear idea.
    By ynneb in forum Mechanical Calculations/Engineering Design
    Last Post: 06-28-2014, 04:20 AM
  2. Worm Gear
    By jackson in forum MetalWork Discussion
    Last Post: 02-07-2008, 10:25 PM
  3. worm gear drive
    By csrc in forum DIY CNC Router Table Machines
    Last Post: 07-03-2007, 08:53 PM
  4. Ha5c Worm Gear
    By engine tech art in forum Haas Mills
    Last Post: 05-10-2007, 02:08 AM
  5. Worm gear hobbing question
    By Dfennell in forum MetalWork Discussion
    Last Post: 02-02-2007, 01:48 AM
