586,652 active members*
2,768 visitors online*
    Apr 2008
    Extruded Aluminum build?
    Has anyone done a JGRO or Joe build using extruded aluminum for the frame, bed, and gantry?
    I’ve been a woodworker for quite some time, but have no metal working equipment.
    However, looking at the extruded aluminum at this site, http://www.tslots.com, I should think you’d be able to bolt together a frame and gantry without any real metal working equipment. I have used my woodworking equipment to cut aluminum to size so I expect this should be possible.
    I was just wondering if there was anyone out there that’s given this a try.
    Karl
    Apr 2008
    Extruded aluminum build
    Yes, many people have done extruded aluminum builds. I am new at this, but one seemingly popular choice has been the extrusions from the 80/20 company. They also have an ebay store which sells surplus at reasonable rates. They also have bearing solutions which have worked for some people as well.
    I personally am going to go for the JRGO style using gas pipe for runners, but largely because I am trying to stay super cheap. The 8020 stuff looks like a great method of construction.
  1. need to build a cnc router / mill for aluminum
    By axkiker in forum DIY CNC Router Table Machines
    Last Post: 07-30-2013, 07:36 AM
  2. 8020 Aluminum Build
    By klick0 in forum CNC Wood Router Project Log
    Last Post: 07-09-2008, 03:32 PM
  3. Build CNC machine out of aluminum?
    By jeffmorris in forum DIY CNC Router Table Machines
    Last Post: 03-24-2008, 05:06 PM
  4. How to clean text off of extruded aluminum?
    By InspirationTool in forum MetalWork Discussion
    Last Post: 12-11-2006, 10:11 PM
  5. Extruded Aluminum
    By DDM in forum DIY CNC Router Table Machines
    Last Post: 03-06-2004, 06:47 PM
