586,385 active members*
3,345 visitors online*
    Dec 2005
    134
    Help getting started
    I recently bought a milltronics lathe with a cent V controller. It has the capability of being programmed in g code or conversationally. I have stumbled my way through a couple of programs conversationally by looking at the one example I could find in the manual and then doing a lot of guessing. But I am far from happy with my progress. I am wondering if anyone here would be willing to help me out a bit. Say for example, give me a step by step if I included some simple part drawing. Any help would be much appreciated. By the way, I am fairly familiar with programming knee mills and I regularly use a TRAK lathe at my other job so I am not totally in the dark but I think a little help would go a long way here.
    Joe
    Oct 2006
    13
    Joe,
    Just to let you know I believe you asked some questions about the post processer for bob cad for you lathe and they only have one for the Cent. 6 Have you tried using this post processer? I talked to Milltronics yesterday and as far as a cent 5 vs cent 6 goes most all g-code are the same so for simple programs the post processer for the Cent 6 may work for you. I have not used Bobcad for programing a lathe only mill so I can't be a lot of help beyond this.
    Jason
    Dec 2005
    134
    bobcad post
    Jason,
    Thanks for keeping me in mind and letting me know regarding the cent 6 post. I have not tried that but I will. I am a one man shop (well, my 16 year old son helps me when I get in a bind) and I only do this on the side - so time is not a commodity that I have a lot of. If I had time to play around with the control and the bobcad software I am sure everything would be fine and dandy but as it is I am always pressed to the limit to get some job or other out the door and I am always trying to pick people's brains so I can make faster progress. Thanks for your input. It means a lot to me.
    Joe
  1. How do YOU get started?
    By mrcodewiz in forum MetalWork Discussion
    Last Post: 04-21-2008, 04:07 PM
  2. Need some help getting started
    By ranchak in forum DIY CNC Router Table Machines
    Last Post: 09-18-2007, 02:25 AM
  3. Getting started with CNC
    By Axisgr in forum Open Source CNC Machine Designs
    Last Post: 06-02-2006, 02:55 PM
  4. getting started on the Z
    By craftech in forum DIY CNC Router Table Machines
    Last Post: 01-10-2005, 12:52 AM
  5. Getting Started
    By johnm99 in forum DIY CNC Router Table Machines
    Last Post: 11-12-2004, 10:59 PM
