586,655 active members*
2,296 visitors online*
    Oct 2005
    169
    Question Missing steps?
    Hello,
    I just removed an anillam control from an lagun mill and installed the following:
    1. Viper 200 from Larken for X,Y,Z
    2. 3 USD 500 cpr encoders
    3. Bob Campbell's BOB
    4. Mach 3 software
    If I set a zero, walk away an inch, and then walk back my machine is off 02" to .04". It does this on all axis and is cumulative. I have tried playing with the pulse settings and switching to a different BOB and no Luck!
    Has anybody experienced this problem before?
    Brandon
    Jan 2004
    105
    Double checked your steps per unit values for each axis?
    Monte
    Oct 2005
    169
    yep.
    Jan 2004
    105
    Quote Originally Posted by beezerlm View Post
    yep.
    So when you walk away an inch, does the table move an inch (1.000") AND the DRO indicates the same inch (1.000")? Have you tried moving further in the same direction?
    Monte
    Feb 2008
    Unhappy
    Somebody help:
    The more pulse (2000 pulse) of encoder is the more accuracy will get?
  1. Missing steps on just a certain part of the part
    By ZipSnipe in forum Stepper Motors / Drives
    Last Post: 01-02-2008, 08:40 PM
  2. Servos jumpy n missing steps....
    By bigal in forum Gecko Drives
    Last Post: 09-29-2006, 09:52 PM
  3. Missing steps ?
    By DavyD in forum Machines running Mach Software
    Last Post: 05-10-2006, 08:06 AM
  4. Full Steps -vs- Micro Steps
    By DJB282000 in forum CNC Machine Related Electronics
    Last Post: 12-29-2005, 06:25 AM
  5. Missing Steps with Laptop
    By alanc2 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-08-2004, 08:39 PM
