586,717 active members*
3,163 visitors online*
Results 1 to 11 of 11
    Mar 2007
    15
    Thread Milling
    I am trying to program a 1/4-18 not with a single point tool on my Haas mill unfortunately. All the software I use wants to use a single pass tool. Any help would be great.
    Dadeslot
    Mar 2008
    26
    Using a thread mill style tool?
    2932
    I believe his post says "single point tool".
    Out of curiosity, Dadeslot, why not tap the hole?
    One more question, does your machine have the User Macro option turned on?
    Jan 2006
    4396
    Quote Originally Posted by Dadeslot View Post
    Dadeslot
    Right Hand Thread
    Start the tool at the bottom about 1 or 2 threads past the bore.
    Lead into the Pitch Diameter and call your cutter compensation so you can adjust the PD.
    Helically CCW Interpolate two passes up.
    Cancel your tool compensation then move to the next bore.
    ex. Using tool centerline single hob thread mill with a diameter of .65D
    N3
    T3M6
    G90G54G40G0X2.04Y-1.875S7000M3
    G43Z1.H3
    Z.1M8
    G1Z-.6F50.
    G41G1D3Y-2.331F20.
    G3X2.04Y-2.331Z-.5167J.456
    X2.04Y-2.331Z-.443J.456
    G40G1Y-1.875F50.
    G80G0Z.1M9
    Z1.M5
    G91G30Z0M19
    M1
    Toby D.
    Schwarzwald
    www.refractotech.com
    2932
    This one may get you close. It's programmed with a 3/8" single-point thread tool. No guarantees.
    Attached Files Attached Files
    Mar 2007
    15
    Thanks that looks like what I came up with. I am using a Haas tool room mill so a pipe tap stalls my spindle + I have over 200 holes to tap in hastaloy I have tried the hob mills they do great for 2 or 3 parts but don't hold up well and at 150. a pop not cost effective. I have have good luck thread mill std threads in the past so hopefully this will work.
    Thanks for the replies
    Dadeslot
    Jan 2006
    4396
    Dadeslot
    Hastalloy, yummy stuff. Use two cutters. First cutter take a few roughing passes, then the final pass with the second tool. Your tool life will improve and you will be able to get through more parts. Hasalloy is gummy and hard so light cuts are not a good idea. Use a cutter that has a Titanium Aluminum Nitride Coating.
    Try Harvey Tool fair prices for micro grain carbide thread mills.
    Toby D.
    Schwarzwald
    May 2007
    15
    thread milling
    seco tools offers thread mills that will suit your application.
    they are a bit pricey but they work great.we thread mill heat treated inconel 718 all day long, no problems.also if you go on their website they offer a downloadable interactive program called "thread milling wizzard" .just answer questions as you go along and it will give the g-code for any threading application.hope this helps
    Oct 2006
    7
    1/4-18 threaded holes
    How thick is the work piece ? If it's less than an inch, use a high spiral cobalt tap. Also use a thicker mix of coolant, or tap heavy. Use a rigid taping method as well.
    It's all what works. Threadmills are great time savers. I always use them on larger threaded holes. They are great for blind holes. When all else fails, use a tap and heavy lube.
    You probable knew this all ready. But, I never know who I'm talking to. Brginner or otherwise.
    Good luck
    Jan 2004
    3154
    Vardex has great coated threadmills as well.
    They also have a free program (download) to generate the threadmill code.
    Much easier to use than Seco's and isn't a massive download.
    www.integratedmechanical.ca
    Apr 2008
    29
    we use Advent thread mills. On a recent job we made a 1/2"-14 NPT took two passes ran 750 pieces in 316 st. st. and only made one adjust.
  1. thread milling
    By fourperf in forum Fadal
    Last Post: 03-11-2008, 01:14 AM
  2. Thread Milling
    By ragman in forum MetalWork Discussion
    Last Post: 02-05-2008, 04:04 AM
  3. Thread milling
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 12-01-2007, 04:01 AM
  4. thread milling
    Last Post: 11-21-2007, 04:32 AM
