586,655 active members*
4,003 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > STarting NEw project - Need Serious Help to Understand PArts before starting
    Feb 2008
    6
    Hi , My name is Max . i;m collecting info and starting to Build a CNC rounter . for mY MDF project ..
    First i would LISt my NEEDS -
    Cutting Space of 48" x 34 "
    Cutting MDF thickness 20-30mm
    Basic operation ..
    Cutting ODD shape . and letter . as well as engraving of letter and design .
    what would i need if i want the machine to work .
    6-10 hour a day .
    This is my basic needs and of cos i hope what i am building will be durable and lasting .
    Here is a FEw Site i am looking at for the Package .
    http://www.xylotex.com/
    http://www.probotix.com/3_axis_stepp...r_driver_kits/
    http://www.kelinginc.net/ThreeXCNCPackage.html
    xylotex offer one PCB for the 3 Driver .
    which i am thinking if it break down or somehow due to my poor understanding
    damage it .. i would have to replace the whole PBC ..
    but other .. package offer 3 pcs PCB one for eaqch drive .. which if i damage anyone one of then during testing i can replace only the damage one .
    i might be wrong - so do correct me and enlighten me
    i see some fancy Stuff like pendant jogger .
    which i would be interested , anyone know any seller - for the product and what kinda . setup would i need s.
    If you know other site with PAckage Kit -- and you think is A good option to view at please - provide URl thanks you
    i have been loooking at kelinginc stuff and a few other package seller out there for the Motor and drive package .. but all this technical term is confusing me ..
    So to start off
    the Stepper Motor . - what would one suggest .. Servo or steeper -
    what kinda Stepper size would i need.
    the price diffrent of NEMA 23 seen much cheaper .. would it be enough for my task ..?
    IF NEMA 23 is the choice . what Oz would be better . 270oz or 425oz ? the price different is not much .
    WHat is a Breakout Board . -????
    Can i use USB .. or upgarde in future if i need too .
    chances is i would run my System on a Cheap old laptop .running on WIN xp .
    I am also having problem to find a LEad screw for my cutting size --
    can someone point be a direction ?
    more or less i should have no problem making the TAble for cutting .
    but the technial aspect on the steeper and computer is a kinda confusing for me .
    what would be a good software to use - i am good at illustrator on adobe , but not sure if . 3d is the same ..
    if you have package which you think is good or better please kindly suggest and put your reason why .
    well i am looking at about 300-500 usd for the 3 axis package . to start off .
    and kelinginc seem to be offering alot of parts .
    Spindle
    base on cutting MDF that is 20-30mm thick .
    what would be a stable good spindle - hope to keep price below $200
    with lot of option to upgrade or after market parts . some spindle might be good but the drill bits and parts is expensive - i am guessing .
    do suggestion . what is good .or what is best for my project .
    i am so new to al this please advice , suggestion correct me if am wrong in anyway .
    Mar 2008
    683
    I think you might be out of the hobby league trying to build a machine as durable as you're requirements. 6-10 hours a day is going to require a very robust machine. And MDF is a horrible material to route because the dust clogs up everything.
    I would suggest you look for some good used routers or even a new one. Komo, Thermwood, Gerber, all make wood routers. It sounds like you'll be in a production environment so get yourself a production machine, it will pay off in the long run. Also make sure to get an automatic lubrication system.
    If you're just starting out a new business you might want to save your money and until you can afford a production machine send your parts to a local cabinet shop.
    Good luck.
    Here is some CNC router for your refrence
    http://www.kelinginc.net/CNCmachines6090.html
    You are build a big CNC router, I would suggest you to use the NEMA 34 package:
    A:3 PCS KL-8078 80V, 7.8A Driver
    B: 3 PCS NEMA 34-906 oz-in Stepper Motors
    C: 1 PCS KL-6515, 65V/ 15A,Unregulated Power Supply 1000W,2
    regulated outputs 5Vdc and 12Vdc at 1A
    D:1 PCS C10 Breakout board, E-Stop or Limit Switch can be wired
  1. Starting a new laser gantry project
    By MacGyver in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-12-2008, 12:56 AM
  2. Starting to cut my first Joes 2006 parts
    By aolshove in forum Joes CNC Model 2006
    Last Post: 11-24-2007, 02:48 PM
  3. Starting my winter project
    By davef2f in forum Benchtop Machines
    Last Post: 11-05-2007, 01:14 PM
  4. Starting a new project
    By chuckknigh in forum CNC Wood Router Project Log
    Last Post: 11-21-2005, 02:55 AM
  5. Finally starting on router project
    By ehiebert in forum DIY CNC Router Table Machines
    Last Post: 04-11-2004, 01:07 AM
