586,835 active members*
2,965 visitors online*
Results 1 to 10 of 10
    Oct 2007
    19
    Tool nose radius offset question
    I'm trying to figure out why a particular program runs fine in one mori lathe, but not another, when both have very similar controllers (both are Mitsubishi Meldas 60 series - one is a MSG-803 and the other is a MSG-805). The problem is that one machine will not activate tool compensation, and the other works fine. I have a bunch of flanged bushing shaped parts, of varying sizes, to produce, and have written a parametric program, that includes a couple of G71 roughing cycles for the project. Things are up and running on the lathe with the MSG-803 controller, however, when I transferred the exact program to the lathe with the MSG-805 controller, tool nose comp is apparently not working??? The obvious things like tool nose radius, and tool tip designation (i.e. 3 for the turning tool / 2 for the boring bar) have been entered into the machine that is not functioning properly. I don't know what else to check. As a matter of fact, the programming manuals for each machine are virtually the same, in regard to automatic tool nose radius offset. I may be wrong, but I'm inclined to think the problem is something other than the program. It is probably something really simple and basic that I'm overlooking. Any help would be much appreciated.
    Apr 2008
    7
    SL machines? A quick thing to check, do they have the same MAPPS software version?
    System / System Config / MAPPS Software ( )
    Oct 2007
    19
    Denny - One is a CL-253 with the MSG803 controller and the other is a SL-204 with the MSG805 controller. I'm not sure about the MAPPS version(s). I just shut them down and am on my way out. I will be in tomorrow to get some set-ups done for Monday's production, and I will try to determine which version of the MAPPS software each controller has - Thanks.
    Apr 2008
    7
    Check the cycle format setting. F0 or F15. If a change is made, you need to power cycle the machine for the format switch to take effect.
    Oct 2003
    352
    I have 2 new NL's with Mapps3. I ran the first program this after noon in the NL-3000Y. The tool nose and comp worked fine, but as soon as the G71 finished, I got an alarm p160(i think). It has something to do with the cutter comp cancel and the return to tool change position. I am using an existing post for my Haas SL-30 that works fine. The Apps guy said it would run fine but it has alarmed every time I ran the part.
    The program looks something like this:
    TIP DIRECTION: 3 TNR: 0.0156 CUTTING X NEGATIVE
    (2.00 SANDVIK DEVIBE B/B X 20in. BAR )
    G54
    G00 G53 X0 Z-15.
    G50 S2000
    G96 S550 M03
    X-2.480
    Z.1
    G71 P101 Q103 U.02 W.0 D.055 F.0085
    N101 X2.76
    G01 G42 Z0. F.004
    Z-19.
    X-2.5 Z-19.207
    N102 G40 X-2.480
    M09
    G00 G53 X0 Z-15.
    M30
    Does anything look funny.
    I think the biggest thing I can't get used to is all of the door locks on these new machines. PITA!!!!!!!!!!!!!
    Apr 2008
    7
    the G71 line has P101 and Q103, the can cycle starts at N101 and ends with N102. I think you need to change the "Q103" to Q102.
    G54
    G00 G53 X0 Z-15.
    G50 S2000
    G96 S550 M03
    X-2.480
    Z.1
    N101 X2.76
    G01 G42 Z0. F.004
    Z-19.
    X-2.5 Z-19.207
    N102 G40 X-2.480
    M09
    G00 G53 X0 Z-15.
    M30
    I think the biggest thing I can't get used to is all of the door locks on these new machines. PITA!!!!!!!!!!!!![/QUOTE]
    Oct 2003
    352
    That N103 was a typo. It is N102 in the program. I have Ellison working on it. They sent the program to Mori in Irving to look at it.
    The machine finishes the cycle but alarms as it hits the clear point.
    Nov 2006
    38
    Try cancelling comp on a dummy Z move instead of the X move.
    Nov 2006
    38
    Quote Originally Posted by JV58 View Post
    Are you getting an alarm or is it just over/under cutting?
    Jun 2008
    this is an older post, so this has probably been fixed by now.....
    G54
    G00 G53 X0 Z-15.
    G50 S2000
    G96 S550 M03
    X-2.480..............are you sure you want to go to X-
    Z.1
    G71 P101 Q103 U.02 W.0 D.055 F.0085....if boring, shouldn't the U be minus?
    N101 X2.76
    G01 G42 Z0. F.004
    Z-19.
    X-2.5 Z-19.207.........same
    N102 G40 X-2.480......same
    M09
    G00 G53 X0 Z-15.
    M30
    also, on my CL's noes comp is not turned on during roughing, only gets turned on in finish cycle...G70 P101 Q102
    when comp is on, any move straight up/down in X needs to be at least twice what comp value is.
  1. Tool Nose Radius
    By speeeeed in forum Haas Lathes
    Last Post: 07-20-2014, 04:02 PM
  2. tool nose radius comp
    By joe1970 in forum G-Code Programing
    Last Post: 02-25-2010, 04:43 AM
  3. G42 Tool nose radius.
    By al-108 in forum Okuma
    Last Post: 03-02-2008, 08:39 AM
  4. Fanuc 16T tool nose comp question
    By dmcool in forum Fanuc
    Last Post: 07-23-2007, 05:21 PM
  5. Tool Nose Radius Fault with Program
    By Josh-PTP in forum Haas Mills
    Last Post: 06-30-2007, 11:03 PM
